Hi Beams Gone - Ford Powerstroke Diesel Forum
6.4 Electronics Discussion TV's, Radios, everything electric and NON-Performance.
post #1 of 4 Old 04-25-2013, 01:21 PM Thread Starter
Kenjamin's Avatar
Quoted: 3 Post(s)
Hi Beams Gone
Everything worked fine on my truck until I installed a set of HID's. After finally having enough grief with that setup I went back to regular Halogen bulbs only now when I put the hi-beams on they turn off. I have switched bulbs and checked all my fuses in the fuse boxes. Im thinking there's an additional inline fuse for the hi-beams somewhere under the hood. I'm sure someone out there knows a lot more than I do. Thanks in advance.
Kenny
2008 F-350 Harley Davidson Edition
- S&B Cold Air Intake
- Vista-Pro Radiator (Lifetime Warranty)
- H&S Mini Maxx Tuner
- Custom BLACK Ford Oval Emblems
- MBRP 4" Downpipe Back DPF/CAT Bungless Delete With Muffler, Stock Tip
- MBRP 3" Intercooler Pipe
- EGR Deleter Kit With Elbow
- Sinister Coolant Filtration Kit
Kenjamin is offline
post #2 of 4 Old 04-25-2013, 03:12 PM
Term3's Avatar
Check the wiring at the headlight to see if it shows signs of overheating. May have shorted out as a result.
Sent from AutoGuide.com App
SCT, no studs...yet, Dual OEM intake air filter housings, Banks intercooler & intake elbow, Banks exhaust system, Windrunner ported intake manifold, Bullet Proof Diesel remote oil cooler & thermostat, AirDog2 (plus a couple spares), Power steering filter (Amsoil dual-bypass), MagTec deep ATF pan, Electric oil pre-lub pump, Dakota Digital gauges.
Term3 is offline
post #3 of 4 Old 04-25-2013, 03:23 PM Thread Starter
Kenjamin's Avatar
Quoted: 3 Post(s)
Ya ok, I'll check for signs of shorting out. I'm assuming I'm looking for burned wires and a fix would be to re connect the wires to the headlight harness. I'm a noob when it comes to electrical, sorry.
Kenjamin is offline
post #4 of 4 Old 04-27-2013, 05:05 PM
Term3's Avatar
You can buy new headlight bulb connectors with wiring from Ford or NAPA
Term3 is offline
