Radio won't turn on - Ford Powerstroke Diesel Forum
6.4 Electronics Discussion TV's, Radios, everything electric and NON-Performance.
post #1 of 6 Old 04-20-2013, 07:13 AM Thread Starter
Radio won't turn on
Hey guys, i have a job 1 08 F250. So i got in the truck the other day to head up town and I noticed my radio wouldn't power up. It's a stock single disk ford factory radio. I've checked all of the fuses and they are all good. Everything else works fine in the truck and the rest of the dash has power it just acts like the radio is the only thing not getting power. Anyone else had this issue??
wattersfarms is offline
post #2 of 6 Old 04-20-2013, 06:43 PM
dieselforfun's Avatar
Quoted: 2 Post(s)
I know its a long shot but check the connection on the back of the stereo unit
dieselforfun is offline
post #3 of 6 Old 04-20-2013, 07:07 PM
KCCO!!
kells17's Avatar
I would do the same, check connection in the back of the radio. I also had an 04 F150 single disc and it would quite working from time to time. I reset it by disconnecting battery for a few minutes, reconnected battery and it worked fine. Never knew what caused it. If still nothing, maybe run a continuity test on the fuse panel?
2004 F-250 Lariat CCSB
Studded, Deleted, Cold Air, Fog Light Mod,
IPR HF Coolant Filter, High Idle, Atlas 40 FICM,
CCV, Edge Insight CTS, ZooDad, BPD Oil Cooler,
4" Banks Monster Exhaust, Fumotos, 05 Harley Headlights,
Blue Spring, Kill Switch, 03 Turbo and 6.4 Banjo Bolts
VA Strokers
757 Diesel
kells17 is offline
post #4 of 6 Old 04-20-2013, 09:43 PM Thread Starter
I actually pulled the radio and checked all of the connections. Everything looked good and it did nothing. Also unhooked the battery cables for an hour and still nothing. I guess I'm gonna have to get a schematic from the dealer and check all of the power wires coming into the radio to see of they are all getting power. Thank you guys for your input tho
post #5 of 6 Old 04-20-2013, 09:57 PM
PowerstrokinIt F250's Avatar
i would just get a nice aftermarket radio. fairly cheap and easy to install. ive seen the stock ones fail alot.
[IMG]http://i59.tinypic.com/33l06ll.jpg
1995 f350 7.3 4x4 auto 4door long bed 160,000 miles BONE STOCK for now. Cleanest truck in PA
1998 Mitsubishi Eclipse GSX 9.9@ 152mph
2003 Honda Civic daily driver
PowerstrokinIt F250 is offline
post #6 of 6 Old 04-21-2013, 05:30 AM
stinkbug's Avatar
Wattersfarms where are you located? If your near Virginia beach i have a stock radio if you want it!
Sent from AutoGuide.com App
stinkbug is offline
