Go Back   Ford Powerstroke Diesel Forum > Ford 08 and newer 6.4L Powerstroke Forums > 6.4 Electronics Discussion
6.4 Electronics Discussion TV's, Radios, everything electric and NON-Performance.
Old 02-08-2008, 12:27 PM
ejh25 ejh25 is offline
Prodigy Brake Controller on 2008?
I'm going to get a trailer tomorrow and the guy there said he has a plug and play harnesses for the Prodigy brake controller that will work on a 2008. Does anyone know if this is true?
How do I gain access to the plug?
Thanks,
Eric
Here is the install:
BTW the OEM plug is behind the coin holder right next to the upfitter switches. This was a real simple install. I pulled the coinholder, ashtray, and ashtray backing out (a flat head screwdriver can help with this). The IBC plug can then be fed down towards the ashtray and below the dash. I then mounted the P3 and connected the wires and that is history.
Old 02-08-2008, 12:56 PM
Banshee34 Banshee34 is offline
Not sure about an 08.... Bumping this up for ya.
Old 02-09-2008, 02:54 PM
metro7100 metro7100 is offline
Not sure about the 08 but I had a prodigy on my 00 X, there was a small female plug under the dash that you plug it into. The Prodigy comes with the male end to match it (not fun to get to, unless your flexible).
PS this one is for sale
Old 02-10-2008, 08:52 AM
up2nogood up2nogood is offline
Originally Posted by ejh25 View Post
I'm going to get a trailer tomorrow and the guy there said he has a plug and play harnesses for the Prodigy braket controller that will work on a 2008. Does anyone know if this is true?
Thanks,
Eric
I researched where I bought mine, I could not find anything offered for the 08, you might want to call them.
Just google PPL its a RV Dealer in Texas. I thought the 08 had the intergrated brake controler ?????
Old 02-11-2008, 06:58 AM
Thanks. You have a PM about your controller.
Sweet pics in the snow btw.
- Eric
Old 02-11-2008, 08:00 AM
Okay, I see that there is a P3 controller out there, should I go with that over the Prodigy?
Thanks,
Eric
Old 02-11-2008, 08:12 AM
Rescuediver Rescuediver is offline
SMOKE ROLLER
I loved the Prodigy on my last PSD, my 2005 has the built in controller (which is why I sold it) you'll love it. If it has a plug N play adapter it world the money even if it hard to get to. It's much better than having to splice wires under your dash and makes for easy removal...
Old 02-11-2008, 08:38 PM
I went with the Prodigy P3 and I have a pigtail harness that will plug right into the OEM IBC plug and it has 4 wires that will be soldered to the P3 harness. No splicing into the factory harness and everything will be easy to remove.
Thanks for all the help guys.
- Eric
Old 02-17-2008, 06:52 PM
Updated with pics of the install.
