Unlock DVD in nav unit? - Ford Powerstroke Diesel Forum
6.4 Electronics Discussion TV's, Radios, everything electric and NON-Performance.
post #1 of 10 Old 04-11-2013, 11:10 AM Thread Starter
davidsiv's Avatar
Does anyone know if you can buy a module to unlock the navigation while driving. Can you also play DVDs on the navigation if its unlocked. Thanks for the help in advance
Sent from AutoGuide.com App
What did I do before I had A Iphone?
davidsiv is offline
post #2 of 10 Old 04-17-2013, 11:58 AM
Quoted: 5 Post(s)
Id like to know as well...about the nav use while driving. The last two Honda's that my wife drove (Odyssey and Pilot) both could be manipulated while driving.
2008 King Ranch CC/LB
DPF Delete, S&B CAI, H&S Mini Max, EGR valve and cooler delete, new downpipe, level Kit, double steering stabilizer, 35's on 18's, Bilstien's, and a Valentine V1
caliboy@heart is offline
post #3 of 10 Old 04-18-2013, 02:08 AM
stinkbug's Avatar
You have to locate the parking sensor lead and ground it. This tricks the unit into thinking the vehicle is stopped. I have seen kits that install to allow dvd playback also never really dealt with that but they have been on Ebay.
stinkbug is offline
post #4 of 10 Old 04-25-2013, 07:20 AM
Id like to know as well. Im pretty sure it works by gps. My nav is unlocked if im stopped in drive or am even creeping along slowly.
X2guy is offline
post #5 of 10 Old 05-07-2013, 11:01 AM
theplumbingmedic's Avatar
Any insight to this ?
2010 F350 lariat cc sb srw
H&S Black Maxx,S&B CAI,,Readylift leveling kit,,GY 325/60/20,Smoked Recon: tail lights,cab lights,3rd brake light and tow mirror lights,AVS smoked window vents,20% window tints,Curt front mount hitch,Rear hitch mounted lights,Sinister coolant filter,PMF dual steering stabilizer,PMF traction bars 51 Gal. Titan tank,Bilstein 5100`s,Rudy`s up pipes,ARP studs,RCD egr delete w/ elbow,AFE cold side pipe,AFE 4"dp, AFE 5"
exhaust
theplumbingmedic is offline
post #6 of 10 Old 05-09-2013, 10:27 AM
duc18v's Avatar
This is the only thing ive found other than finding the parking sensor
FORD LOCKPICKS
duc18v is offline
post #7 of 10 Old 05-20-2013, 08:07 PM
Lock pick is the only way
2008 King Ranch F-350 CCLB dually
Mods: H&S Mini Maxx, Flo-Pro 5" DP back straight pipe, Flo-Pro egr delete with elbow, Flo-pro CAC tube, S&B CAI, 2.5" Leveling kit, Sinister coolant filter kit, Recon cab, fender, mirror, third brake light, and line of fire, Headlight and fog light HID's
Mods to come: ARP Head studs, 71mm turbo, downpipe, 6.0 manifolds, custom up pipes, suncoast converter and tranny
02 F-550 auto stock for now and all for $1
Farmrod is offline
post #8 of 10 Old 05-21-2013, 04:19 AM
I have been in the process of trying to get my Coastal Tech Lockpic to work on my 2010 F250 w/Navigation.
The first one I installed and seemed to work during the initial install. I had the vehicle in Drive & was able to view the DVD and turn on the rear camera at will.
When I came back to my truck later that night, the DVD refused to play in any gear other than Park. I was only able to turn on the rear camera.
A call to tech support had me try a few items. They noted that my Bluetooth should have been disabled during the install which mine wasn't. After a long phone call we decided to swap for a new unit.
The new one came in last week. I installed it and got the same exact results as the old unit!! WTF.
I plan on calling tech support AGAIN this morning.......NOT HAPPY!
-Mike
2010 F250 CCSB Lariat FX4
MikeSherman is offline
post #9 of 10 Old 05-21-2013, 09:47 AM
OK - the tech talked me thru how to get into the Radio Diagnostic Menu and check/clear any DTC codes.
There were two listed. Once I cleared them the unit appeared to work as advertised. Now to get some useage out of it.
-Mike
post #10 of 10 Old 05-22-2013, 10:00 AM
Damnit!
Success was only short lived. The problem came back after the next key on/off sequence!!
At first he wanted to send a 3rd unit - I doubted 2 bad units back to back so we brainstormed some more...
The tech said the most popular platforms are F150-F450 trucks and doesn't know why mine is so fussy. Then I mentioned I was running a tuner......he then felt pretty sure the tuner and lockpick are not playing well together.
I find it hard to believe all the F250-350's with this brand lockpick are all stock or perhaps it just doesn't like the H&S tuner.
Either way this was a failure. I'm yanking it out of the truck and sending it back for a refund.
-Mike
