Factory sub hook-up - Ford Powerstroke Diesel Forum
6.4 Electronics Discussion TV's, Radios, everything electric and NON-Performance.
post #1 of 11 Old 04-03-2013, 03:56 PM Thread Starter
Factory sub hook-up
I located the plug behind the passenger back seat but the connector is a 6 head "male" piece and the plug into the actual factory sub box is a 10 head female piece. Do they make an adapter piece to link the two? I figured the two ends should have lined up perfect. Anyone ever delt with this before?
2011 F-250 White Lariat
35 Nitto A/T's
FabFour Front and Back Bumper Replacments
S&B CAI
5 inch Flo Pro Straight Pipe
SCT X4 Tuned
Old Rig RIP-2008 6.4 F250 Lariat White/Tan
35 Nitto Mud Tires with 20'' Chrome Rockstars
DPF Delete Straight Piped 4 in. Exhaust with 5 in. Tip
H&S XRT Pro Tune w/ EGR delete
S&B Cold Air Intake w/ K&N filter
Line-X Bed Liner
LED Reverse lights
Kenwood DDX419 Touchscreen
HID 55W 5000K Headlights 35W 5000K Fogs
gauge is offline
post #2 of 11 Old 05-16-2013, 08:02 AM
Thinking about adding a factory Sub so interested in the outcome here.
SMcGann is offline
post #3 of 11 Old 05-19-2013, 01:57 PM
44magnum's Avatar
Quoted: 2 Post(s)
Well on my truck it's a 10 plug. Here is what it looks like. There isn't an adapter on my truck. Factory sub hook-up-imageuploadedbyag-free1369000641.306131.jpgFactory sub hook-up-imageuploadedbyag-free1369000652.473781.jpg
[FONT=Verdana][I][B][SIZE=2]2008 (Job 1) F250 King ranch 4x4, snow plow prep package with 2.5 level. Black Maxx, B&W Diehard platinums. Dieselsite coolant and transmission filters, NCU Motorsports/amsoil oil bypass kit. Turbo blankets, 5.5" blocks & PMF "floating" traction bars
44magnum is offline
post #4 of 11 Old 05-19-2013, 01:59 PM
44magnum's Avatar
Quoted: 2 Post(s)
Do you have the audiophile package? I know there is an extra connector to the back of the radio if you do.
44magnum is offline
post #5 of 11 Old 05-19-2013, 02:08 PM
Yeah it's a Turbo Diesel
mts678's Avatar
Quoted: 12 Post(s)
Feedback Score: 12 reviews
If you don't want major bass why not just stuff an 8" or 10" back there? It'll sound and perform better than the stocker.
Sent from AutoGuide.com App
2017 f250 platinum
Bone stock until warranty expires!
mts678 is offline
post #6 of 11 Old 05-19-2013, 02:30 PM
Powerstroke Techie
Cause the stock housing/amp/sub is CHEAP and comes as an assembly, and it fits perfect.
I did some looking around awhile back on this, and it showed two different body harnesses for with/without subwoofer.
Ford Senior Diesel Technician
2008 F-350 4x4 Off Road 6.4 Powerstroke Diesel
There are strange things done 'neath the midnight sun by the men who moil for gold.
The arctic trails have their secret tales that would make your blood run cold.
Big Angry Hillbilly is offline
post #7 of 11 Old 05-19-2013, 02:40 PM
mts678's Avatar
Quoted: 12 Post(s)
Ah I see. Can you use the stock enclosure and put an aftermarket sub in there?
2017 f250 platinum
mts678 is offline
post #8 of 11 Old 05-19-2013, 04:43 PM
Powerstroke Techie
I don't see why not. Never really looked into taking one apart.
post #9 of 11 Old 05-19-2013, 05:23 PM
44magnum's Avatar
Quoted: 2 Post(s)
The stock enclosure is pretty small and not very deep (not to mention, plastic), the JL sub I looked at wanted about 1/2 cu ft box (Ideally). I wouldn't imagine it would be worth it to put a better speaker into it. I left the stock sub and upgraded all 4 speakers to JL's and it sounds much better. If your going to go to the work and expense of putting a good sub in you might as well upgrade the box, and if your going to do that you might as well upgrade the AMP, they you have to redo the wiring..... As Im not an audiophile its just not worth it to put a new amp/box/sub/wiring into it.
FYI i think the stock sub is 8".
44magnum is offline
post #10 of 11 Old 05-20-2013, 08:39 AM
I got a factory sub off Ebay for $60. Thought I would try it first. If it doesn't give me the sound I want then I will sell it and go bigger. I am not looking for "big" bass I just want to get those lower freq in there so when I replace my other factory speakers I can cap them and still have the sub frequencies present. So I just want over all sound quality but with out going through the trouble and expense of an all out custom set up.
SMcGann is offline
