cruise control not working - Ford Powerstroke Diesel Forum
6.4 Electronics Discussion TV's, Radios, everything electric and NON-Performance.
post #1 of 2 Old 03-29-2013, 05:17 PM Thread Starter
nathan619's Avatar
I have a 2010 F350 Diesel.
The cruise at first, worked one day and not the next, then it completely stopped working.
After research, I replaced my cruise control release switch that's mounted under the brake master cylinder. I tested the old switch after removing it and it checked good so I knew the new switch wouldn't make it work and sure enough, the cruise still won't turn on.
My horn and brake lights work.
Any ideal what I can check next? I don't even know where the fuses are but I doubt they are bad since the cruise would work intermittant at first before it went out completely.
99 F-350 CC Dually 4x4. Completely stock.
10 F-350 CC SRW 4x4. Completely stock. (Sold)
16 F-250 CC 4x4. Stock
nathan619 is offline
post #2 of 2 Old 04-11-2013, 12:09 AM
It can also be your clutch switch. If your struck starts without depressing your clutch all of the way to the floor, your cruise control will not engage. It only takes five minutes to replace the switch. It is mounted on the clutch lever itself. The price ranges from $26-65. It could also be the clock spring mounted inside your steering wheel, but check the clutch interlock switch first.
prheitz is offline
