installed HID kits in my projector headlights and cant get low beam - Ford Powerstroke Diesel Forum
6.4 Electronics Discussion TV's, Radios, everything electric and NON-Performance.
post #1 of 5 Old 03-24-2013, 10:45 PM Thread Starter
Strokin_4_Life's Avatar
Send a message via MSN to Strokin_4_Life
so I bought 2 H1 HID kits (low and high beams) to install in my projector headlights and I hooked everything up which was straight forward and I cant get my low beams to come on, high works perfect. When I turn the light switch from auto to all running lights on I can get a flicker. I took a test light and I have no power at the low beam wires...but when I take the HIDS out and put the stock bulbs back in power is back and everything works fine.
What am I missing?
thanks
2008 F350 SC,SB 6.4L 4x4
- leveled on 325 hankooks
- 20'' moto metal 961s
- pmf trac bars
- spartan tuned
- low pressure batmowheel
- studded
- PS67 4'' downpipe
- 5'' exh, to single 7'' miltre stack
- S&B intake
- DD IC pipe, egr delete w/cfm
- MTX Audio
Strokin_4_Life is offline
post #2 of 5 Old 03-28-2013, 07:49 AM
stinkbug's Avatar
Thats weird. What ballast wattage are you running? I have 8k hids in mine with 35w ballasts.
Sent from AutoGuide.com App
stinkbug is offline
post #3 of 5 Old 03-28-2013, 07:55 AM
kirbybc12's Avatar
Subbing to see what it is. Same issues with my girlfriend's Ram. Lights work with truck off, flicker once it starts and go out.
2012 F-350 Lariat FX4 CCSB
2.5" Carli Commuter
Carli High Mount Steering Stabilizer
AFE Cold Air Intake
Truxedo Lo Pro QT
Line-X
Dura-Flap Mud Flaps
Timbren SES
High Idle
35x12.5x20 Toyo AT II Extreme
H&S Mini Maxx, 4" AFE Turbo Back
kirbybc12 is offline
post #4 of 5 Old 03-28-2013, 08:09 AM
stinkbug's Avatar
Cycling the light switch sometimes fixes the ballast trigger. Not sure if running higher wattage affects this! Mine flicker when they come on then once warmed up they run normal and thats for both high beam and low. I have had ballasts burn out but the first time a ballast went bad they were over a year and a half old. Now I have two spare ballasts in my tool bag just in case.
stinkbug is offline
post #5 of 5 Old 03-30-2013, 09:16 AM Thread Starter
so I drove my truck into the shop and as soon as the front end hit the dark all the running lights and low beams came on, took it back outside later that evening(dark) and nothing still cant figure this out. my ballasts are all 35w.
- pmf trac bars
- spartan tuned
- studded
- PS67 4'' downpipe
- S&B intake
- MTX Audio
