eBay projector headlight hid setup question - Ford Powerstroke Diesel Forum
6.4 Electronics Discussion TV's, Radios, everything electric and NON-Performance.
post #1 of 22 Old 03-23-2013, 03:00 PM Thread Starter
Mcaattcckk's Avatar
http://bit.ly/11rlmpk
That's the link to what I want...I'm not trying to drop 500$ on Recon headlights as I'm doing an audio build at the moment as well...
Questions I have concerning this:
-do I need any sort of relay harness to get these HIDS to work?
-do I need to do anything to disable day time running lights (according to this it has a seperate bulb that runs that)
-is anything need to be modified or disabled etc. to be able to continue using the auto feature on my headlight switch
-lastly judging by the view of these projectors is the top portion (non projector) the high beam area? Cuz I would like highs and lows which I do understand needs another kit
-apply all of my previous questions to the same for upgrade of fog light HIDS to match. Will they need a relay harness etc.
Thanks guys!!!!
Sent from AutoGuide.com App
MOBBSIXX.com
Mcaattcckk is offline
post #2 of 22 Old 03-23-2013, 03:03 PM
zdawg8394's Avatar
headlights may be a problem i just installed some hids and they wont work with the truck runnin they only flicker so my guess is i need a harness. my hid fogs work flawless though with out a harness. i would recommend one for both but im only doing one in my headlights
zdawg8394 is offline
post #3 of 22 Old 03-23-2013, 03:06 PM Thread Starter
Mcaattcckk's Avatar
Ok so your saying harness for both just to he on the safe side...I'm also assuming even if u don't need relay harness still safe to get it and using it won't make a diff.?
MOBBSIXX.com
post #4 of 22 Old 03-23-2013, 03:43 PM
zdawg8394's Avatar
correct that way the hid's arent pulling all their power from the stock harness. on startup they need and use alot of power but after start up they draw less. i would do it to be safe.
post #5 of 22 Old 03-23-2013, 03:49 PM Thread Starter
Mcaattcckk's Avatar
Ok plan is to get ddm tuning 55w. So I guessing I need the wiring harness and the no error adapter also? Is that correct? And I'm assuming same for the fogs?
Also the 9008 is a dual filament bulb correct? Or will I need 2 sets to retain high and low beam? I'm not new to hid but I haven't messed with this stuff in a few years just want to make sure I'm getting the right stuff without getting unnecessary items
MOBBSIXX.com
post #6 of 22 Old 03-23-2013, 05:42 PM
zdawg8394's Avatar
it looks like that comes with the hid kit? and dont do 55w on the fogs it may burn the housing. i would do 35w on heads and fogs to make sure the colors are the same ( 55w tends to be more white vs 35w of the same k) those are 8k by the way and i dont believe they have high beams at all. just low beam projector. the top light is for running/ turn. and the other round light is for drl maybe?
post #7 of 22 Old 03-23-2013, 05:46 PM Thread Starter
Mcaattcckk's Avatar
Makes sense I guess I'll have to call them to verify. I just know that bixenon HIDS have a actuator which causes them to slide backwards and get a different angle on the hood of them causing the beam to point higher just didn't know if it would work or not. Guess that's another question for the ddm guys. Thanks for the help!!
MOBBSIXX.com
post #8 of 22 Old 03-23-2013, 05:58 PM
zdawg8394's Avatar
i dont think it will work in a projector cause they use a shield to make the cut off... but no problem!
post #9 of 22 Old 03-24-2013, 03:49 AM Thread Starter
Mcaattcckk's Avatar
Ahhhh got yah. Ok then!
MOBBSIXX.com
post #10 of 22 Old 03-24-2013, 05:42 AM
Quoted: 45 Post(s)
When I asked about those lights I was told they were crap. Hope it all works out.
2015 F350 DRW Platinum, SCT X4, EDGE CTS2, aFe PDS, AirLift 5000 Ultimate & Wireless Air, Lund LED Bull Bar, RC Grille bar, B&W 5th Wheel, Stark LED Lighting
2010 F250, H&S Mini Maxx, aFe PDS, Diamond Eye 4", Pro Comp Nitro 2.5", Bilstein 5100, SmittyBilt Bull Bar, Bushwacker Pocket Style, B&W Slider, Firestone Ride-Rite, Fuel Hostage 20x10, Pioneer/Kicker/JL Audio
RUFFSTUFF is offline
