| 6.4 Electronics Discussion TV's, Radios, everything electric and NON-Performance. |
Projector Retrofit: How-to
Okay, so last year I started this project and it got put off for some time. I finally got the time to work on it so I wanted to post up some pics and info on what I did in case anybody else is interested in doing this. There is a thread on hidplanet.com about this called JnC's Mounting Method (with Rotational Adj Capability)
which describes a process used called the JNC method. While I didn't exactly follow this route, because the instructions are sometimes vague and confusing, I sort of developed my own method using his technique. First, I ordered the parts from The Retrofit Source online: headlight upgrades for all applications who helped me out and answered all my questions. Excellent products and customer service! Parts list: Bi-Xenon FX-R Stage 3 Projector Kit (Morimoto Five5 Ballasts, Morimoto Five5 6k bulbs, LHD (left hand driver) projectors, Butyl Resealing glue, Panamera Shrouds) xB LED White 120mm white 80mm rubber caps to seal the back of the light Dremel tool Blue painters tape #10 bolts, washers, nuts (I think they are #10x24 1") Tap/drill bit set for #10 bolts Easy-Off oven cleaner Black Spray Paint (for painting shrouds and side marker lenses) And probably a few other parts I am forgetting First things first, remove the headlights from the truck and disconnect all lights (parking light, side marker, headlight). Next, remove the screws on the back of the headlight housing (I think there are 3 black screws deep down in the holes on the back of the light. I did one headlight at a time so I didn't have to rush and get them done. You could also order a spare set of lights so you can take your time with this project. You're going to need to heat up your oven to 220 degrees and put the light in there for 20mins. Make sure you put the rack at a very low position so your lamp doesn't bump the heating element up top or get too hot. Next, remove the lamp after 20mins and set it on a towel so it doesn't move around. I wore a glove on one hand so I could hold the lamp down and not get burned, while using a small flathead screwdriver to pry open the light. Be very careful prying open the light, so you don't break the plastic tabs around the outside of the light. Slowly work your way around the entire outside edge of the headlight and break the seal of the glue. This could take you 10mins or so, so don't get impatient and screw up your light. Once you have broken the seal, start trying to pull the light apart. You should hear the glue starting to give way to the point the light comes apart. If not, you may need to heat it up again to soften up the glue. If your careful, you can pull the glue out in a few long strands and have a nice clean channel for resealing later. [IMG] [/IMG]Remove the plastic yellow sidemarker lens (if you want to paint it like I did). Now you need to remove the bowl from the headlight. There are two plastic tabs on each of the plastic pieces holding the bowl in place. CAREFULLY use a small flathead screw driver and pry each claw open enough to slide the head of the screw out. Each piece has a claw on opposite sides so once you pry both, you need to apply pressure outward so the claw don't re-engage. Once both are loose, you can pull the bowl out and remove it. You can choose to remove your chrome finish inside your bowl like I did, or leave it. If you want to remove it, use the easy-off oven cleaner and it will just melt away.[IMG] [/IMG]![]() ![]() Once this is done you can mark the back of the bowl using a sharpie marker. Use my picture as a reference by marking along the same lines on your headlight. Note the vertical lines and use them as a reference. ![]() ![]() Use your dremel and cut out this pattern once it's marked properly. Don't worry about making the edges all pretty, nobody is going to see this part. Next you have to make the L brackets. This part sucked because I don't have a bench vise and had to bend them using a hammer and a concrete edge. I think I found it's not worth using steel (so you can tap it) instead just using a flexible metal like aluminum or buying a pre-made L bracket. If you use a pre-made of some type of metal you can't tap, make sure you nylon lock nuts to secure everything down and prevent it from coming loose later. But you can follow my route too and buy a strip of steel and bend it, tap it, and form it. Whatever method you choose, you need a 90 degree L shaped piece of metal. The lengths aren't important because you will need to trim them later, but it has to be short enough on the back side of the projector to fit in the small space, and it will be cut down on the front to be as short as possible. It will look like this ![]() I also tapped the two bottom holes on the projector and the top hole that will be on the inside of the projector for each one. If you tap both top holes because I just confused you, it doesn't matter. One won't be used anyways. ![]() ![]() You can see where I used a rubber washer and a steel washer or two to get the alignment right. After that's all done I will add a nut on top to hold everything down securely. Next I took a piece of white blank paper, and cut it to the same shape as the inside of the bowl. Once I got it pretty much cut to size, I place it inside and eyeballed the projector to line up straight. I pulled the paper back about 1/8" to compensate for the plastic lip on the front of the bowl. The paper is going to be used as a template later and placed on the bottom of the bowl. Once that's done, use your marker to mark around the edges of the L brackets. Now remove the paper and the projector and flip the bowl over. Place the paper up against the bottom of the bowl and the fornt edge. Use the diagram you made to drill thru the paper as close to the front edge of the L bracket as possible. ![]() You can also place the paper on the bottoms of the L bracket to mark where you drilled into the bowl so the holes line up. Now tap your L bracket if your doing it the way I did.Test fit everything to make sure you measured right ![]() This is where you're going to need some time to go back and forth. Once you got the projector fit in the headlamp, you're going to need to get your alignment down pat. When I first started here's what it looked like. The lights are so bright I was able to do it in the daylight ![]() Finally got it to look like this after some adjustments. ![]() I used the factory headlight screw inside the headlamp to adjust my up and down when I got it down to fine tuning. If you need a rotational adjustment like I did at first, I added/removed washers between the L bracket and the bowl. Make sure you replace all the bolts that hold the lamp onto the truck each time you make adjustments. These bolts being tighter on one spot can affect your aim. I just made the adjustments keeping the clear front lens of the headlight off, and attaching the body of the lamp with the projector on it to the truck. Once you get the aim/alignment downpat, you're ready to move on. The rest will be continued later this week. |
WOW great write up of the JNC Method Tony. Makes me wish I did my retrofit that way instead of using epoxy putty and bolts. Maybe for my next retrofit I will use this...
Nice write up man. Post some pics of your final out come, I'm anxious to see em!
Sent from AutoGuide.com App |
Thx guys, will do. That write up took hours between stopping to take pics, uploading them, writing directions, and posting them. I'm trying to finish it up tomorrow. I think you will be pleased with the outcome.
Once you got the alignment all worked out, now it's time to finish up with the shrouds and LED's. I used the Panamera shrouds and painted them black with Valspar Plastic Spray Paint from Lowe's. No primer needed. The Panamera shrouds give you the ability to remove the clear plastic lens inside so you don't need to tape anything off. Once they got 3 coats of paint, I trimmed them to fit inside the bowl using a dremel. I also used shroud centric rings (they came with the kit) which help with fitting the shroud onto the projector lens. I will warn you though, the fittings on the shroud and the rings are very stiff and brittle. I broke a few of them off just trying to test fit the stuff, but it still holds on just fine. ![]() I used the 120mm White XbaLED Angel Eyes from TRS.com. They fit in the shroud nearly perfect, although I did have to cut a small notch for the wires to sit in. I used a push-pin to poke a hole thru the shroud and used monofilament fishing line to tie it in place. Silicone isn't recommended due to high heat failure ![]() ![]() ![]() Now, get your butyl tape and you may need to stretch it out a tiny bit so it fits in the groove around the edge of the housing. Once you get it all layed in there, you're almost done. Fire up the oven to 265 degrees on bake, don't forget to move the rack to the bottom so you don't melt the lens. Press down the lens onto the bead of butyl and add a little pressure. Be careful though as your housing will probably be resting on the back of the projector. After that, throw it in the oven for 7 minutes at 265. Pull it out, press down on the lens again to give it a good seat then let it cool. That's about it folks! I used the 80mm rubber dust caps from TRS.com to seal up the back of the projector. I used a sharp razor to cut out the center of the cap about the size of a quarter and then ran the wires for the angel eyes and the high beam motor thru there as well. Connected the HID plug and it's a pretty tight connection. Re-installed everything and ran my power feed for the LED DRL's to upfitter switch #1 so it can be left on when the truck is on but will shut down once it's turned off. ![]() The pic of the headlights is looking down my block, with the 55w kit 6k, low beams. Lights up the roadway like the sun. Very happy with them. Only issue I have is I knocked the alignment off slightly on one of my projectors when I was pressing down the lens after removing it from the oven. Good thing is that there is plenty of butyl tape leftover so I will probably open it back up and re-align it once it annoys me enough. ![]() ![]()
Truck looks sick man!! That is a nice unique look tony, looks killer!
Looks BA, nice work!
Thx fellas, I agree. Very happy with it.
So you can just put the headlight on a rack inside the oven and it won't melt the plast that's touching the rack? I plan on taking mine apart soon, cause I'm gettin condensation in my lights and I want to get it all cleaned out real good
