Go Back   Ford Powerstroke Diesel Forum > Ford 08 and newer 6.4L Powerstroke Forums > 6.4 Electronics Discussion
6.4 Electronics Discussion TV's, Radios, everything electric and NON-Performance.
Old 12-04-2007, 09:52 AM
boggs187 boggs187 is offline
Seatbelt chime
Does anyone know if the is a fuse you can take out to stop this nuisance?
Old 12-04-2007, 10:04 AM
07stroker 07stroker is offline
I wanna go fast!!!
There are some steps you follow in the manual that will disarm the chime...
Old 12-04-2007, 06:32 PM
DINOONE DINOONE is offline
Go to the junk yard and cut an old seat belt off any old truck, thats what I did?
Old 12-04-2007, 06:35 PM
DKR DKR is offline
<--Pro Cooler Racer
Look up "BeltMinder" in your manual, at least my 07 and several years previous you can do it. Worked for me.
Old 12-04-2007, 07:00 PM
MrJohnWayne MrJohnWayne is offline
Thats Mr. Oil Leak.....
I did the procedures for the belt minder system 2 times now and every time I kill the truck it resets and the stupid chime keeps coming back.
Old 12-04-2007, 07:10 PM
Barchetta Barchetta is offline
Dirty South Stroker
Send a message via AIM to Barchetta
Page 181 -182 in the manual.
Deactivating/activating the Belt-Minder feature (Driver only)
Read Steps 1 - 5 thoroughly before proceeding with the
deactivation/activation programming procedure.
The Belt-Minder feature can be deactivated/activated by performing the
following procedure:
Before following the procedure, make sure that the following conditions
are met:
• the parking brake is set
• the gearshift is in P (Park) (automatic transmission) or the neutral
position (manual transmission)
• the ignition switch is in the OFF position
• all vehicle doors are closed
• the driver’s safety belt is unbuckled
• the parklamps/headlamps are in the OFF position (If the vehicle is
equipped with Autolamps, this will not affect the procedure)
While the design allows you to deactivate your Belt-Minder, this
system is designed to improve your chances of being safely
belted and surviving an accident. We recommend you leave the
Belt-Minder system activated for yourself and others who may use the
vehicle. To reduce the risk of injury, do not deactivate/activate the
Belt-Minder feature while driving the vehicle.
Belt-Minder activation and deactivation procedure
1. Turn the ignition switch to the RUN (or ON) position. (DO NOT
START THE ENGINE)
2. Wait until the safety belt warning light turns off. (Approximately 1
minute)
• Step 3 must be completed within 60 seconds after the safety belt
3. At a moderate speed, buckle then unbuckle the safety belt 9 times,
ending with the safety belt in the unbuckled state.
• After Step 3 is complete, the safety belt warning light will be turned
on for 3 seconds.
• If Step 4 does not occur within 10 seconds at the end of Step 3,
Belt-Minder will automatically exit programming mode without
changing its enable status.
4. Within 7 seconds of the light turning on, at a moderate speed, buckle
then unbuckle the safety belt.
• This will disable the Belt-Minder feature if it is currently enabled. As
confirmation, the safety belt warning light will flash 4 times per
second for 3 seconds.
• This will enable the Belt-Minder feature if it is currently disabled. As
second for 3 seconds, followed by 3 seconds with the light off, then
followed by the safety belt warning light flashing 4 times per second
for 3 seconds again.
5. After receiving confirmation, the deactivation/activation procedure is
complete.
Old 12-05-2007, 12:23 PM
thanks for the help i will give that a shot
Old 12-05-2007, 04:15 PM
melmount melmount is offline
maybe different, but on my 07 and my wifes02expedition their are 2 wires under the seat(drivers) . Both wores go to the same male and female connector. its a grey connector. just unplug it. should fix it?not sure on 08's but if its there try it.
Old 12-06-2007, 10:39 PM
fenwick fenwick is offline
why not just put on the seatbelt?
Old 12-06-2007, 10:54 PM
sawyer1 sawyer1 is offline
"why not just put on the seatbelt?"
My thoughts exactly
