Go Back   Ford Powerstroke Diesel Forum > Ford 08 and newer 6.4L Powerstroke Forums > 6.4 Electronics Discussion
6.4 Electronics Discussion TV's, Radios, everything electric and NON-Performance.
Old 11-24-2007, 02:10 PM
trkrtom trkrtom is offline
Question CB radio & linear
Will a CB radio with a linear amplifier foul up any computer functions on a 6.0 PSD ? (not legal, I know---just curious)
Old 11-24-2007, 02:11 PM
bigcountrysg bigcountrysg is offline
repairs can't be made
No they should not mess up any of the electronics on the truck. But then again it may depend on how big of a linear you are wanting to run.
By the way if you get a shortwave radio license from the FCC you will be legal.
Old 11-24-2007, 02:16 PM
planeoldguy planeoldguy is offline
Dunno bout the new trucks, but I was pushin 1500 watts outa my '99 Chevy 2500 without a problem, just be sure to ground it to the frame, My friend smoked his computer grounding it to the body.
Old 11-24-2007, 02:17 PM
strokermann strokermann is offline
and use steel braided wire. good stuff. its all about the grounding when it comes to cb radio and amps.
Old 11-24-2007, 02:22 PM
Smile
Thanks! I had an old Freightliner with a 335 Cummins, when you keyed the mic with a 200+ linear, it would dim the lights and peg the electronic tach.
Old 11-24-2007, 02:27 PM
all cars and trucks will do that dimming teh lights. my truck does that know. well my wifes truck anyway. with 2 batteries in mine and a 240amp alt i have no problem running a 500 watt amp. just like our trucks with mods cb radios is a power bug also. becareful those things aren't cheap.
Old 11-24-2007, 02:41 PM
todd todd is offline
my tranny hates me
its not the power that the linear puts out that damages engine ecms it the voltage spikes it creates when keying and unkeying the mic when your power and ground are not hooked correctly power direct to battery and ground to frame or battery and if your gonna run more than a 500 watt unit use a capaciter designed for car audio amps any car audio store cb shop or best buy has them the power your linear needs is always there and youll never have a voltage spike and remeber your antenna mount needs a good ground as well and if you want the very best cb the general lee is tops in my book and ive had em all over the years
