Go Back   Ford Powerstroke Diesel Forum > Ford 08 and newer 6.4L Powerstroke Forums > 6.4 Electronics Discussion
6.4 Electronics Discussion TV's, Radios, everything electric and NON-Performance.
  #111 (permalink)
Old 06-17-2008, 01:58 PM
A8050266 A8050266 is offline
Perhaps since it has a DIN/MiniDin plug
disconnect it. take a multimeter and test the hot side.
the side going to the Radio unit. not the camera side
issolate the 12/gnd then all thats left are the Vid wires.
  #112 (permalink)
Old 06-17-2008, 02:07 PM
danno danno is offline
Thats the problem, all I have of the Alpine system is the camera with a 3 ft. cord with a small male 4 pin plug...nothing else.
Dan
  #113 (permalink)
Old 06-17-2008, 02:12 PM
a good friend of mine is the ALPINE rep or the entire SE/USA
let me know the model number off the cam or whatever you can find. and I bet he can get us a Schematic. this way you can be abso sure.
  #114 (permalink)
Old 06-17-2008, 02:16 PM
Thank you I will see what I can find on it tonight!
  #115 (permalink)
Old 06-18-2008, 11:43 AM
A8050266, I took the camera out last night and no where do I see that it says Alpine but, what it does say is the letter "EIA" on the back end and on the top it has a "WB3040060" & "Made in Korea" I also took pictures but I haven't figured out how to post them yet.
  #116 (permalink)
Old 06-18-2008, 12:20 PM
Danno,
this may sound crazy, but you can buy a reverse cam off eB?y for less than 30 bucks "shipped" this may be a route you may want to consider since you will get a cam that you know what,where and how to deal with. just a thought if this cam give you any more fight.
  #117 (permalink)
Old 06-18-2008, 03:36 PM
Is it just a plug&play camera, ready to plug into a new ford? What did you use to search for it on e-bay? I will have a look!
Dan
  #118 (permalink)
Old 06-18-2008, 03:55 PM
danno,
Its just standard Cam with Integrated IR and also a reverse Image.
for example. in my application I used this very cam. do a search on ebay
for Item#150014192301 I am not in any way affiliated with this seller.
it has 120 degrees of view. this cam has 3 wires. Power/Ground and VID.
and your up and running. basically a god value. their are many reverse cams
that could suit your need.
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
