| 6.4 Electronics Discussion TV's, Radios, everything electric and NON-Performance. |
Aftermarket Head Unit
I would like to replace the factory unit. want to keep the sync and steering wheel controls. want a plug and play unit. any suggestion? Cost?
You will need a PAC MS-FRD1 to retain the SYNC and brand specific SWI interface.
Pac-Audio.com Product Search | iPod Integration for your car and More by Pac-Audio - Connecting you to the future |
most aftermarket headunits use there own interface for bluetooth and you can add teh steering wheel control module.
Or get an iDatalink Maestro RR and a compatible Kewnood deck. If you get on the iDatalink Maestro website it has a vehicle chooser and everything. With a compatible head unit this should give you all the features of Sync and retain your steering wheel controls with no extra screens or controllers.
http://maestro.idatalink.com/product...product_id/102 I have read mixed reviews on it though, so make sure you do a bunch of research before you get anything. Last edited by Alaskan_awd; 11-14-2012 at 05:17 PM. |
The steering wheel controls will still work for the SYNC features, but have no control over the radio without a SWI interface.
Edit: I see your credintials....I'm assuming I am missing something here because you most likely do know what you are talking about.... Edit 2: nevermind...I see you were the same as posted above...I see what you are meaning....sorry for that.... |
I should also add even with a SWI interface, you will not be able to program ANY SYNC buttons to control the aftermarket radio. You can program the vol +- or seek up/down.If you want to use the SYNC buttons as buttons to control the aftermarket radio, you will have to disconnect the SYNC module. |
If you don't mind, can you elaborate on the last comment about programming the sync buttons by disconnecting the sync module... that is the issue I am currently having....I want my phone button on the steering wheel to activate the telephone on the Kenwood head unit....is it as easy as completely disconnecting the sync module and following directions to program it through the PAC SWI? |
