| 6.4 Electronics Discussion TV's, Radios, everything electric and NON-Performance. |
Another HID Retrofit Project- 2008 PSD
Here's a progress report thread on my own retrofit project for headlights and fogs. First off here's a list of the parts I just got to get started:
1. Extra set of 2008 Headlights 2. Bi-xenon: Acura TL / ZKW-R Lens Projectors Ballasts: Matsu****a Gen V (35w) Bulbs: New Osram 66240 D2S SVS 4200K Shrouds: Apollo Wire Harness: Relay: H13/9008 Rubber Housing Caps 75mm 3. 2008 Ford Fusion projector fogs 4. H11: Morimoto Elite HID System Ballasts: Morimoto 3Five (35w) Kelvin: 3000K Wire Harness: H10/9145 Wire Harness Type: Heavy Duty Relay I got the lights baked and peeled apart already so now I'm gonna start fitting the projectors and so on... One thing though, wow, those Acura TL projectors are HUGE!!!!
Subbed wanna see how it turns out!
Haha, same components as my install, you'll be awestruck at their performance. That being said, good luck with your build and I'll be paying attention. The more ideas the better in my opinion.
One thing I wanna add, I never understood why everyone out there tells people to use an oven and bake their headlights. Actually I think that's a foolish way to heat the butyl in order to separate the lenses off. One slip in attention or judgement and you end up with melted headlight housings, more often than not they get melted on the mounting tabs. That's why I use a heat gun instead. Get a $20 one from harbor freight and it works just as well without any hazard of melting any of the housing. That and you don't have to stink the house up using the oven too. Works much better in my opinoin... Now that I'm done, GET BACK TO WORK!! ![]() P.s. I like to trim the extra flashing off from around the projector housings with a dremel tool, helps the shrouds fit that much better. I also use a nice clear drying silicone adhesive/sealant to help glue the shrouds on the projectors. It holds extremely well and is soft enough to cut away if the need arises to remove the shrouds. My 2 cents. GL Last edited by nuttcase21; 10-24-2012 at 10:25 PM. |
I will keep the pic's coming as I go forward and show ya how it looks. |
One more thing I forgot to add. I'm gonna use either the bleach method or the oven cleaner method to chemically remove the chrome off the lenses and bezels too before any painting comes into play. This will be the first time I try these but the internet says lots of people have had amazing results, and when does the internet lie!
![]() Here's one persons results with oven cleaner: Oven cleaner - necessary? - Page 3 |
I've seen threads on this before in other forums, but got skeptical about drying the plastic out and creating potential cracks. Be surprised how you can "dry rot" plastic with chemicals. I usually just grab a scotchbrite pad and scuff the reflectors/chrome bits before I shoot them with paint. Haven't had a single spot of paint chip or flake off.
You may want to think about putting some desicant bags inside the headlight too. They help to keep moisture down. I put them in all my retros. I can give you some tips on how to make them if you're interested. |
Yeah that would be great. I would like to do as much as possible to them while they are apart.
Well I have to say I officially give the Easy off oven cleaner method 2 thumbs up. I sprayed the housings with it probably 5 times and rinsed with hot water between coats and it got all the chrome off and left me with nice shiny black plastic pieces. I tried to take pic's of the shiny-ness of the black up close but it looks like a nice exterior paint job. Better than I would have been able to do with a rattle can thats for sure.
Next I'm gonna make up some mounts for the TL projectors and mount them directly to the rear housing. I figure they are too heavy to mount to the reflector. I don't want to take a chance it may droop or sag at all. |
