| 6.4 Electronics Discussion TV's, Radios, everything electric and NON-Performance. |
Is there a way too..... ?
hey guys, ok, heres my question of the day....
I am so sick of the seatbelt chime alarm. i live in an apartment complex and i drive to get my mail and really dont feel like putting my belt on when im only going 5mph or maybe 10mph. So, what i want too know is there a way to pull the plug and just jump the dam thing too make it think the seat belt is connected all the time???? |
Google:
Deactivating/activating the belt minder feature Read steps 1 - 9 thoroughly before proceeding with the deactivation/activation programming procedure. The Belt Minder feature can be deactivated/activated by performing the following procedure: Before following the procedure, make sure that: • The parking brake is set. • The gearshift is in P (Park) (automatic transmission) or the neutral position (manual transmission). • The ignition switch is in the OFF position. • All vehicle doors are closed. • The driver’s safety belt is unbuckled. • The parklamps/headlamps are in OFF position (If vehicle is equipped with Autolamps, this will not affect the procedure). To reduce the risk of injury, do not deactivate/activate the Belt Minder feature while driving the vehicle. 1. Turn the ignition switch to the RUN (or ON) position. (DO NOT START THE ENGINE.) 2. Wait until the safety belt warning light turns off. (Approximately 1–2 minutes.) • Steps 3–5 must be completed within 60 seconds or the procedure will have to be repeated. 3. Buckle then unbuckle the safety belt three times, ending with the safety belt unbuckled. This can be done before or during Belt Minder warning activation. 4. Turn on the parklamps/headlamps, turn off the parklamps/headlamps. 5. Buckle then unbuckle the safety belt three times, ending with the safety belt unbuckled. 105 • After step 5 the safety belt warning light will be turned on for three seconds. 6. Within seven seconds of the safety belt warning light turning off, buckle then unbuckle the safety belt. • This will disable Belt Minder if it is currently enabled, or enable Belt Minder if it is currently disabled. 7. Confirmation of disabling Belt Minder is provided by the safety belt warning light flashing four times per second for three seconds. 8. Confirmation of enabling Belt Minder is provided by: • The safety belt warning light flashing four times per second for three seconds. • Followed by three seconds with the safety belt warning light off. • Once again, the safety belt warning light will flash four times per second for three seconds. 9. After receiving confirmation, the deactivation/activation procedure is complete. |
![]() Took me like 5 min to do this on mine a few weeks ago. |
haha i did mine the first week i bought my truck. it told me how to do it in the manual.
Schwing! Can't wait to do this in the morning
