How to change lights from signal on mirror! - Ford Powerstroke Diesel Forum
6.4 Electronics Discussion TV's, Radios, everything electric and NON-Performance.
Old 08-16-2012, 12:29 PM
Do you pop it out? I don't want to break it!
Old 08-16-2012, 12:55 PM
check in the manual Im sure its there but my guess would be be pop out one side first then gentle pull off.
Old 08-16-2012, 01:17 PM
Thanks I was being lazy ill check the manual like u said!
Old 08-16-2012, 03:14 PM
If you tilt the big section of the mirror all the way out using the power mirror adjuster - Not the telescope..like the mirror panel itself...you can see two little tabs just at the the outside edge. You have to push in these tabs to get the side marker to pop out. I looked, and didn't find this in the manual. I had to order LED replacements from some aftermarket company to get the instructions.
Old 08-16-2012, 06:18 PM
Thanks a lot. I looked in the manual and there was no help. I did exactly as you said and got it the first time! 👍
