| 6.4 Electronics Discussion TV's, Radios, everything electric and NON-Performance. |
Ok so I broke one of my reverse sensors on my truck, just ordered a new one, but I had a couple questions. First off on the instruction for installing a ranch hand rear bumper they say, in bold, not to unplug the reverse sensors. Why is this? Is there a process to replacing one of them? Thanks in advance.
I got a ranch hand bumper for my truck that didnt have holes for my sensors. I figured "No big deal, Ill just punch holes in myself". I did this and was transferring the sensors over one at a time and ended up breaking one clean in half. So I figured I would just put two sensors in, one on each side. Turns out you have to have all four connected to the harness for the whole system to work properly. Right now in my RH bumper, I still have two sensors in, one on each side. I have yet to break down and purchase a replacement sensor. When I do, I will ream out the final two holes and put in the remaining two sensors.
I am not sure if this covers what you are looking for in a return statement, but this is how my truck with RH bumper is set up. |
Also, I found them very easy to remove from the factory harness and plug. Just be extremely careful when trying to disconnect the two. I pulled out the sensor head from the body when I broke mine.
Do you have a pic of your bumper and where you put the holes? I have a RH as well and wanting to install the reverse sensors. My bumper has the lights so not much room to put 4 sensors. I do not know how close they can be to each other or how close to put to the license plate cut out.
thanks for the update and pics. helps a lot.
