2008 oem nav upgrade ? - Ford Powerstroke Diesel Forum
6.4 Electronics Discussion TV's, Radios, everything electric and NON-Performance.
Old 06-20-2012, 03:25 PM
I just installed an oem nav radio on my o
08 kr but the door speakers sound very low. The sub works fine just the mids and highs sound very low. anyone had this happen or anyone have a solution? It had a pioneer double din but was cracked thats why i put the oem on.
Old 06-20-2012, 06:41 PM
Sounds like your amp connection is being bypassed and you're only getting the power from the head unit. I had that problem on my previous vehicle. Did you have to do any splicing of the wires or was it just plug and play?
Old 06-20-2012, 06:48 PM
There was a 1 spliced wire and i connected it back. The nav was in a buddys harley and it was working fine. Where is the amp located o these trucks or how can i fix it
Old 06-21-2012, 02:11 PM
Ttt Anyone?
Old 06-26-2012, 06:39 PM
Send a message via Yahoo to sredmyer
Originally Posted by pewtewr01 View Post
Ttt Anyone?
I have quite a bit of experience with these trucks and the audio systems in them...I can probably help out.
From your description it sounds like the previous poster was on the right track. The radios and navigation systems these trucks came with had internal amplifiers. However the navigation systems out of 09 or newer trucks used external amplifiers. They are not a direct plug-n-play match with your truck. If you have one of these newer navs, you will need to get the amlifier and "T" harness that allows it to be connected. There are also a few other parts that would be required but I will wait to go into that until we are sure that is actually the problem.
So to determine what type of navigation you have, can you tell me the part number of the top of the unit. Should have four digits (letters and\or numbers) followed by 18k931. If you can tell me the first four digits I can tell what type of radio it is.
Steve
Old 07-04-2012, 07:31 AM
Steve
bc3t is what the nubers you want to know... also where is the stock amp located on these trucks. i had an alarm removed and was told that the wires from the amp had been cut i just dont know where its located
Old 07-04-2012, 08:25 AM
I sent you a PM with my contact info...give me a call and I will explain what you need to do.
Steve
