| 6.4 Electronics Discussion TV's, Radios, everything electric and NON-Performance. |
What are Ur Volts running on Ur charging system.. Mine r running at 13.3 is that normal?
Sounds fine.
When is that though? Right after start up, after idling for more than 5 mins? |
I had the dealer check mine before I replaced my batteries (to make sure that wasn't the cause of my battery troubles), if I remember correctly it was 13.8, usually if you are between 13-14.5 you good. Are you having problems? I'm sure there are specs for it just cant seem to find them easily.
