Lights Out - Ford Powerstroke Diesel Forum
6.4 Electronics Discussion TV's, Radios, everything electric and NON-Performance.
Old 02-13-2012, 09:46 AM
Question Lights Out
Anyone ever deal with steering wheel controls/lower dash control switches backlighting illumination not working? Steering wheel control illumination, 4 Wheel drive selections, pedal adjust, headlight controls, dimmer dial illumination... none of these illuminate when headlights are on. I'm assuming a common relay controls these???
JM
Sorry, hate to post & run, but I'll come back to check later.
JM
Old 11-21-2012, 07:58 PM
any answer ? i have this same problem
Old 11-22-2012, 06:07 AM
Unhappy Lights Out
No one ever responded. Still have the issue. Doesn't seem to affect anything else, just a nuisance at night when I can't see the buttons I want to select. I'm thinking it has to be a fuse or some relay... but which one, no idea.
Old 11-22-2012, 07:10 AM
Feedback Score: 8 reviews
Have you checked fuses? I would open up your owners manual and see what fuse those are on and check it.
Sent from my iPhone using AutoGuide.com Free App
Old 11-22-2012, 08:18 AM
My 4 wheel drive dial lights go out. If I tap it they pop back on.
Old 11-24-2012, 07:09 PM
matusj05 ill keep you posted on this i have been fooling around with it. maybe i can solve this problem or my good friends a mechanic and he is going to check it out soon.
Old 11-25-2012, 10:22 AM
I've checked every fuse in passenger side fuse box... all are good. Wondering if there isn't a relay that runs them all. Checked all fuses in power distribution box under hood too... nothing out. I've got nothing to check relays with so I'm stuck for now unless someone else has ideas...
Old 11-26-2012, 09:14 AM
i checked them also..all are good, I'm heading up to my good friends shop this afternoon ill get him to go over everything ,hopefully we can solve this problem tired of driving in the dark and having to turn on a light to set my cruise control
Old 11-26-2012, 09:24 AM
Sounds good - good luck!
Old 12-01-2012, 10:19 AM
matusj05 sorry took so long to get back on here, we looked at it for a couple min but he had to run so no progress yet. does your outside cargo light turn on i'm having problems with that to. i hope to get better look soon.
