Back-up Camera - Ford Powerstroke Diesel Forum
6.4 Electronics Discussion TV's, Radios, everything electric and NON-Performance.
post #1 of 8 Old 02-02-2012, 06:30 PM Thread Starter
Clayton1985's Avatar
Back-up Camera
Wondering if its possible to have the back up camera display show up on the HU rather than the rearview mirror?
2008 Job 3, F350, 6.4/drw/lariat/CC/LB, Spartan, Viper 5902, Line-X, Flo-pro egr delete, aFe stage 2 proguard 7, MBRP Cool Duals/downpipe/CAC, CCV mod, coolant filter PMF 7" 4link, Rigid Dually fogs, Royalty Core 3pc, Crown brake lines, Mishimoto Rad
6.4 Rebuild May/2015, BD manifolds+Uppipes, chromoly rods, rockers,lifters, hd springs
Monstir 20", 37x12.50 ATZ P3
1999 Corvette Cpe
Clayton1985 is offline
post #2 of 8 Old 02-02-2012, 08:02 PM
Alberta Advantage's Avatar
Quoted: 20 Post(s)
If your head unit is capable of being triggered by a 12 volt signal, I believe it should work.
09 F350 CCSB SRW Cabela's.
Husky Weather Beaters
Putco Window Visors
Piaa Xtreme White 4k
Dura Flap SS Mud Flaps
Recon Smoked Mirror, Brake, Tails
Line-X
Bak Flip F1
BDS/Fox 2.0 Dual Steering Stabilizer
Fox 2.0 shocks
Good Year Duratracs
Firestone Air Bags
Air Horn
MiniMaxx/5" TBE
No Limit EGR Delete
Vision X Lights
2" Solstice Solo
8" Evo Prime
12" XMitter Low Pro Prime
4" Solstice Prime
20" Evo Prime Double Stack
12" XMitter Prime Ambers
Truck Bed Lights
Alberta Advantage is offline
post #3 of 8 Old 02-02-2012, 08:09 PM Thread Starter
Its the stock dbl din nav head unit.
1999 Corvette Cpe
post #4 of 8 Old 02-02-2012, 08:21 PM
Quoted: 20 Post(s)
Might be worth a trip to the dealership and talking with the parts guy. I know the 2009 and 2010 with nav and camera setups have the reverse camera monitor in the nav unit. Could be as simple as a new wiring harness.
Putco Window Visors
Line-X
Bak Flip F1
Fox 2.0 shocks
Good Year Duratracs
Firestone Air Bags
Air Horn
MiniMaxx/5" TBE
No Limit EGR Delete
Vision X Lights
2" Solstice Solo
8" Evo Prime
4" Solstice Prime
Truck Bed Lights
post #5 of 8 Old 02-02-2012, 08:37 PM Thread Starter
Yeah, I thought the later years had it displayed on nav unit. I could go see what dealer thinks, id think someone on here has tried/wondered the same thing?!
1999 Corvette Cpe
post #6 of 8 Old 02-03-2012, 02:36 PM
No, the 2008's have a pioneer based factory Nav unit that doesn't have a video input. There are few companies out there that offer a way to add an AV input. I tried using one from costalEtech. I took the headunit apart, put in the AV input, re-installed the headunit and it didn't work (like wouldn't even play the radio), removed the headunit, put it back to factory and it worked again. Tried re-installing the AV input two more times with the same results. Sent it back to coastalEtech, they sent me another one, same results again. SO, I'm going with there product doesn't work. Haven't tried any of the other compaies yet.
Antonm is offline
post #7 of 8 Old 02-03-2012, 04:18 PM Thread Starter
Ah, thanks for the info!
1999 Corvette Cpe
post #8 of 8 Old 02-04-2012, 10:00 AM
Quoted: 2 Post(s)
That is good info... I was thinking about pulling the trigger on one of those... I really cannot find that many who have actually installed this... I did find a guy who retrofits the newer sync system to the 2008 model trucks. I have emailed him, but not talked to him yet. I think it is very expensive...
ridesdirt is offline
