Upfitter switch or Custom switches? - Ford Powerstroke Diesel Forum
6.4 Electronics Discussion TV's, Radios, everything electric and NON-Performance.
post #1 of 12 Old 01-01-2012, 01:16 PM Thread Starter
Send a message via Yahoo to skipnay
Ok guys my wife bought me the LED lights for the bed area. I'm also going to be installing more lights like something in the front where the front license plate area is. Anyway my question is should I use the actual upfitter switches or should I make a piece of aluminum and make my own and put the switches in that I want?
Also is there relays already in the truck or should I just get the relays for myself? I have wired enough stuff over the years I know that you can't just run power from the battery to a switch and back to the light without have problems. So is there any wiring behind the dash I can use or not?
Alot of questions sorry. But want it done right.
2010 My Wife has 2 Full time JOBS NOW
2008 F250 H&S MiniMaxx, S&B CAI, and cat/pdf delete
2008 Brute Force 800 All hooked up 67hp to the wheels
2007 Got Married
2004 KFX 700 Stock Bore Kit XX cams
1990 Mustang Notch getting ready to hook it up
1988 Mustang GT 449hp to the wheels 6sp Getting a cage installed
skipnay is offline
post #2 of 12 Old 01-02-2012, 05:45 AM Thread Starter
No one has an answer or opinion? LOL I would also like to let you know I have plastic sheets I can use anywhere from a thin to thick piece. They are flat pieces and they are black.
2007 Got Married
skipnay is offline
post #3 of 12 Old 01-02-2012, 05:47 AM
shapiros's Avatar
The down side of the upfitter will be they are only powered with acc or running. Installed the upfitters myself after-the-fact. They are extremely easy to install. A harness exists to hook them into already. I like the factory look myself is why I went with them. I have a radar detector, GPS, fog light override and strobe lighting (fog and backup) on mine.
Not sure what relays you are referring to that currently exist...
2010 F250 FX4 Sterling Grey CC SB 3.31 Gearing
  • 20" Pro Comp Wheels
  • 34" Nitto Terra Grapplers
  • Ionic step bars
  • Husky Liner mud guards
  • ReadyLift leveling kit
  • UWS toolbox
  • LineX bedliner
  • AVS vent shades
  • H&S Mini Maxx Tuner
  • Flo-Pro DOC/DPF delete
  • AFE Stage 2 Pro 5r intake
  • HID Bi-Xenon 55W, 6000k temp headlights
  • Complete LED interior/exterior lighting including front switchbacks
  • Webasto 4300 sunroof
  • AmSoil (engine, trans transfer and diffs coming)
shapiros is offline
post #4 of 12 Old 01-02-2012, 05:48 AM
FJuanfiddy mod
Dave's Avatar
Quoted: 10 Post(s)
Use the upfitters. Its your best and easiest option. They are fused and the relays are already there.
Email:
2006 F250 ECSB Lariat 4x4
Edge Insight CTS
Coolant filter
Dave is offline
post #5 of 12 Old 01-02-2012, 06:43 AM
Sawed Off's Avatar
Id use the upfitter switches also. Its more of a stelth look instead of drilling a hole and installing a different switch.
2010 SUPERDUTY
6.4 CREWCAB
Mods so far!!
Smoked Recon lights
Predator8 wheels
Toyo open country tires
Dpf/Doc delete
H&S tuned
S&B cold air intake
Sawed Off is offline
post #6 of 12 Old 01-02-2012, 06:59 AM
Quoted: 48 Post(s)
why wouldn't you just wire the radar detector to the purple key-on wire? just curious
drunk on diesel is offline
post #7 of 12 Old 01-02-2012, 07:32 AM Thread Starter
Ok where are you guys getting these Upfitter switches? I can find switches close to the factory ones and I would make it look factory....
2007 Got Married
skipnay is offline
post #8 of 12 Old 02-07-2012, 06:08 PM
I would also like to know where you get them. Thanks guys!!
ohmartm is offline
post #9 of 12 Old 02-07-2012, 10:17 PM
GregsSD's Avatar
Quoted: 15 Post(s)
Garage
Here are some kits on ebay:
2008 ford upfitter switches | eBay
2005 F-250 CC/SB 4x4 medium wedgewood blue
5" lift, 5" Donahoe rear springs, 35x13.50 MTZ's, 18x12 Fuel Hostage wheels, 4.30 gears, Banks 4" exhaust, Airraid intake, SCT from Innovative, ARP headstuds, Bulletproof ficm, Bulletproof EGR cooler, Scangauge II, Randy Ellis Design lightbar, Street Scene flares, Harpoon mod, Zoodad mod, LED 2010 taillights, Switchback LED front turn signals
GregsSD is offline
post #10 of 12 Old 02-07-2012, 10:44 PM
kahmann's Avatar
Feedback Score: 7 reviews
Ford Truck Parts - Full Warranty On All Ford Truck Parts
2008 Ford F-450 FX4 Lariat
Edge CTS with EGT
Draw-Tite gooseneck hitch
Odyssey batteries
Recon smoked fender LED lights
Recon LED cab lights
Transfer Flow 30 gallon refuel tank/toolbox combo
kahmann is offline
