| 6.4 Electronics Discussion TV's, Radios, everything electric and NON-Performance. |
Here is the question to the masses. Where are the sensors located on the DPF ? My next question are these sensors suppose to read normally open or normally closed. The reasoning behind this is I want a DPF but I don't want a programmer. The truck has the power
Next up is the cruise control has stopped working. Any thoughts on this one? |
Only way to do it is with a tuner that reprograms the PCM to turn off the regen function. This question has been asked allot with no result other then having to get a tuner.
If all you want to do is turn off the regen function, the lowest priced tuner that does this is the DPF-R+, under $500 just for the tuner. Don't know what to tell you about the cruise control. |
