CB radio Coax install location - Ford Powerstroke Diesel Forum
6.4 Electronics Discussion TV's, Radios, everything electric and NON-Performance.
Old 07-06-2011, 03:55 PM
Looking to add a cobra 29lx to my truck. Just wondering where everyone is running their coax into the cab from? Im looking to get a mount for the corner of my box and running it underneath. Pics would be helpful...thx
Old 07-06-2011, 04:02 PM
I always run mine under the cab and then up and through the fire wall.
Old 07-06-2011, 04:08 PM
The firewalls on these 6.5 are pretty jammed packed. I remember hearing about a cover under the back seat that a few people ran cables through. I just don't want to put any holes in my cab.
Old 07-07-2011, 03:15 AM
I put mine through a hole in the floor beneath the drivers foot area. I replace the rubber plug with a grommet and siliconed around the wire. My feet don't rest there while driving so I have no worries of chafing the wire.
Old 07-07-2011, 03:30 AM
Would you mind sharing some pics of this plug you found? Others have mentioned it, Im still not seeing it. Or you just drilled a hole and Im not catching on to that fact...either way pics would be awesome. THx !!
Old 07-07-2011, 03:55 AM
I would like to see also.
Old 07-07-2011, 01:18 PM
Someone on here did a pretty sick install, mounting the antenna on the drivers side, just behind to the engine hood, opposite the stock radio antenna. I'll let ya know if I can find the post.
Sorry... no luck finding it.
Old 07-07-2011, 05:16 PM
bueller....bueller....gonig tomorrow to pick up my radio, how do i route this thing...lol
Old 07-08-2011, 08:30 PM
nm i FOUND it...beer goggles didnt help. I will post up tomorrow for you Ryan !
Old 07-08-2011, 08:33 PM
I ran my power, coax, gauge wires and any other wire that may need to be fed threw the firewall threw the clutch master cylinder hole. If you pull the carpeting back up behind the parking break pedal you should be able to see the tape they have over the hole, or maybe see it from the engine bay, can't rember which is eaiser to see. It will be to the outside of the brake master cylinder.
