| 6.4 Electronics Discussion TV's, Radios, everything electric and NON-Performance. |
Need Advice On Sound System Install
To start off I stopped at the local audio store that carries JL products and the guy in there was about as usefull as whale **** on the bottom of the ocean floor. He basically could give me no information on what would be the best option for me.
This will be going in a 2010 CC with the power sliding rear window. I have the factory sub, but that isn't loud enough. The door speakers are also not very loud. With the windows down I can hardly hear aything 50' away. I'm looking to budget under $1000 for everything. I already have a TMA 500/1 amp that I used to push 2 JLW1's and will use that. I'd like to go with JL throughout the whole truck unless someone suggest a better option. For the sub it'll be the JL13tw5 and for the door speakers it'll be some basic JL 5x7's. I don't plan on putting an amp on them so no need for a component system. Can someone point me the right direction as for what I should get and where to purchase the sub, 5x7's, box, wiring, and radio adapter from? |
and I am looking for a system with the same setup you were looking for a few months back...u find any advice? Thanks in advance!
Well, i see you are in louisiana, our sound law is 15' away from the truck incase you were wondering.
With that being said, for loud sound, you NEED amps. JL subs are the way to go, JL mids on the other hand.. their just ok. What kind of head unit do you have, or plan on getting? Also, with a nice subwoofer setup, you will def want to amp your mids/highs because they wont be loud enough. .. that is if you are like me, and over do stuff. |
jk. I'm going to run a 6.7 Nav head unit, so i won't be putting out crazy bass. I used to run a sick system in my F-150, and as I have gotten over, I'm more into the crisp sound, and when i get drizzle I like to crank it up a bit, but I don't want the cars next to me to listen to my music too ![]() Now when it comes to horsepower and tuning... YES, I'M VERY OVER THE TOP!!! ![]() Thanks for the response bro. |
Well as long as you are going for a little louder, yet crisper and better quality, that head unit will def be fine. A nice set of 3 ways and one nice sub would be good for you.
I wish I could deal with sticking with simple like that. And as for the louisiana comment. That was for the OP. |
Thanks mane!!! cheers!![]() BTW...I just figured out how to use the smiley faces...awesome!!! hehe
I have not yet got around to installing the system yet. I picked up a JL 13 from a buddy who traded his truck in. I have an amp already. So all I need is to buy the box from SPKL2 then install it all. I'm going to use my factory Nav head unit. As for high and mids I'll keep factory then eventually change out.
have you checked DD audio?.. for $1000 you could get everything you need and make your ears bleed
