My problem is when i turn my headlight switch to the on position the lights delay before coming on. its about a 7-10 second delay and then they come on and function properly. If i turn the switch just to the perking light position this setting works properly (the parking lights come on just like they shoud) but again if i go from the parking light position to the headlight position there is a 7-10 sec. delay before the headlights actually turn on. The auto headlights also have the delay if I turn it to the auto position.
Leading up to the problem i was attempting to install recon accessories cab lights and I took the headlight switch out thinking that I could just tap into the parking light wire to control the new cab lights. I later found out that you must tap into the wire coming out of the smart junction box. So now I do have the cab lights mounted and working but I have the headlight delay problem. I did touch a standard chepo test light to all the leads on the headlight switch when I thought I could just tap into one of those wires. Anyone know what my problem could be???? PLEASE someone help.:dunno:
