Go Back   Ford Powerstroke Diesel Forum > Ford 08 and newer 6.4L Powerstroke Forums > 6.4 Electronics Discussion
6.4 Electronics Discussion TV's, Radios, everything electric and NON-Performance.
Old 06-27-2007, 08:04 AM
rdkl rdkl is offline
Send a message via AIM to rdkl Send a message via Yahoo to rdkl
How to remove Nav Radio?
Does anyone know what is required to pull the stock nav radio? I am considering switching to a Pioneer unit and cant find any information on what kind of puller might be needed.
Thanks!
Old 06-27-2007, 08:16 AM
bigcountrysg bigcountrysg is offline
duct tape & zip ties
You can get an install kit from almost any parts store or car audio store that will have the tool to pull the stock radio out. I know guys that have made there own tool out of a coat hanger.
Old 06-27-2007, 08:17 AM
I was going to add the din removal tool on crutchfield but they say I dont need it for that head unit so I am really confused
Old 06-27-2007, 08:20 AM
Your radio has four little holes in each corner or on the side correct. Those holes have a locking mechanism inside them. You put a small metal rod in those holes and pull outward away from the radio and then pull the radio out towards you using the metal rods. Unless Ford changed the way the radios are mounted in the dash that is how it should be removed.
Old 06-27-2007, 08:29 AM
Just went out and looked. I dont see 4 holes but it does look like I'd have to remove the dash panel in the middle to get at it.
Anyone know how hard that is to do?
Old 06-27-2007, 11:52 AM
I haven't tried this yet but I was told you can remove the 2 triangular pieces at the bottom of the dash section (one side is cig lighter and pedal height and the other is the aux input) and below those are bolts holding the dash panel on.
In case anyone else was wondering
Old 06-27-2007, 12:43 PM
ryan20021982 ryan20021982 is offline
Here is up to the 2007 but the odds are its different but might be helpful
http://www.cbsfa.com/imageuploads/file49.pdf
Old 07-05-2007, 06:40 PM
superdutylariat08 superdutylariat08 is offline
i just took out my nav raidio in my 08.. it was only held in by 4 screws..
Old 07-06-2007, 08:50 AM
Thanks guys. I got the instructions from a guy I was talking to. Finished installed the Pioneer Avic Z2 last night. Great setup but alot of wiring with all the modules I installed... I am glad that project is finished
Now on the sub install...
Old 07-06-2007, 09:30 AM
Blue01F250 Blue01F250 is offline
Tournaments Won: 1
Man I want one of those Pioneer's!!! will be a while though
