I have some 2 10' rockfords to put in my truck. Im just going to build a box to sit in my back seat. I was wanting to know, is there a way to wire it to my factory head unit(6 disk changer)? if so what would be the best way and produce the best sound?:dunno: Thanks for all help.
Well you have 2 choices. Either get a in line converter and splice into your rear speaker wires, to convert it to RCA ends for your amp. Or the way I was going to do it and get a JL audio clean sweep eq. It will allow you to adjust your highs, mids and lows. So you dont have higher frequencys going through your subs. Which the way you are talking I would go this route. Its called a JL audio CL441dsp clean sweep. Check it out! Hope this helps you out bud
Related Threads
Ford Powerstroke Diesel Forum
5.4M posts
265.8K members
Since 2005
