Getting ready to in stall a JVC KW-NT3HDT and so far it looks pretty straight forward. The only question I have is about hooking up the "speed signal lead". The instructions say to connect it to the "signal lead from the speedometer". I'm guessing it's a wire off of a a harness somewhere but I don't know what to be looking for. Anyone know which wire this would be on an 08 6.4 F350?
Also hooking up the reverse gear signal lead the instructions just say to hook it into a reverse lamp lead at the reverse light in the taillight. Sound about right? Thanks for any help out there.
PASSIVE ANTI-THEFT YES TRANSPONDER SEE NOTES
This vehicle is equipped with an IMMOBILIZER passive anti-theft system. Please refer to the security diagram before any remote start installation.
12 VOLTS Blue/red Ignition switch harness +
IGNITION White/orange Ignition switch harness +
ACCESSORY Violet/Green Ignition switch harness +
ACCESSORY 2 Brown/yellow Ignition switch harness +
STARTER Blue/white Ignition switch harness +
KEY SENSE Blue/gray Ignition switch harness +
TACH SIGNAL Blue In driver's kickpanel (loose wire) AC
May also be found in harness left of steering column.
LOCK Blue/green In driver's kickpanel -
UNLOCK Yellow/purple In driver's kickpanel -
DOORPIN Blue In harness from under driver seat +
BRAKESWITCH Violet/white At brake switch +
May also be Yellow/green in driver's kickpanel.
PARKLIGHTS Violet/white In driver's kickpanel +
HAND BRAKE White/violet In driver's kickpanel -
HORN Yellow/red Steering column -
CLUTCH SWITCH Blue/orange In driver's kickpanel
HMMM None of the wires he asked about are mentioned in your reply.
Heres what I found. Hope this helps.
Reverse - Green/Red - Left side of dash under steering column +
Speed Sense - YELLOW/BLUE - (AC) - AT ABS CONTROL MODULE ALSO AT WIPER MOTOR
Related Threads
Ford Powerstroke Diesel Forum
5.4M posts
265.8K members
Since 2005
