Go Back   Ford Powerstroke Diesel Forum > Ford 08 and newer 6.4L Powerstroke Forums > 6.4 Electronics Discussion
6.4 Electronics Discussion TV's, Radios, everything electric and NON-Performance.
Old 11-01-2009, 10:54 AM
dc4 dc4 is offline
High Idle/BCP question
I had to run the purple ignition hot-in-run wire to my seic wire for my high ide mod cause I didnt have upfitter switches. I ran the purple and yellow/green wire to a simple switch mounted on my dash that i installed. Now if I wanted to enable the battery charge protection mode could I split that purple ignition wire so it runs to another switch with the purple/brown BCP wire
Old 11-02-2009, 10:32 AM
judd.mcclure judd.mcclure is offline
I wanna go fast!
Yes you can do that without any issue.
