Go Back   Ford Powerstroke Diesel Forum > Ford 08 and newer 6.4L Powerstroke Forums > 6.4 Electronics Discussion
6.4 Electronics Discussion TV's, Radios, everything electric and NON-Performance.
Old 10-30-2009, 07:13 PM
71stang99 71stang99 is offline
09 Factory Stereo
I have the 6 disk MP3 4 speaker setup. I want to upgrade towards the audiofile system which from what I read is a 8 speaker with amp.
Where is the speakers located with the audiofile system?
Where is the amp located?
Is the factory wiring in place to plug and play?
Does the non audiofile head unit (mine) have the needed connections?
Thanks
Old 10-30-2009, 07:28 PM
geabis geabis is offline
Thanks
help us out. what model year are you driving and what cab configuration standard, super or crew.
please post and i'll be happy to help how ever i can
Old 10-31-2009, 06:13 AM
Harley350 Harley350 is offline
The connections should be there ( I've been told Ford only makes one wire harness). As for the speakers if depends on which cab you have. The amp for the sub is in the sub box and the one for your head unit is inside. If your truck did not come with audiophile then your unit does not have the pin-outs for it so you would need a new head unit. Your unit has two plugs, audiophile unit has three.
Now allow me to aim you in a different direction. Why not just add an after market amp, sub and speakers to your factory head unit. You can do two or one amp install. One amp will run both but most people who want a really good sounding system have two amps, one for main speakers, one for the sub. After market sounds "WAY" better then the OEM. IMO the OEM sounds like junk, I should know I have/had one.
Old 10-31-2009, 08:25 AM
The truck I have is an 09 350 CC, I need to create a signature. thanks
