2008 F250 cruise control not working - Page 2 - Ford Powerstroke Diesel Forum
6.4 Electronics Discussion TV's, Radios, everything electric and NON-Performance.
post #11 of 22 Old 11-13-2009, 01:43 PM
O2ShootTheJ's Avatar
Originally Posted by ZeroOne View Post
On another forum, someone had the same issue. No matter how many times they pressed "ON" and "SET", it didn't work. Turned out to be the brake pressure switch. The truck thought the brakes were applied, so cruise wouldn't work.
thats what i was thinkin mine was b/c i have the Brake switch B code. guess i was right! gonna get it looked at around Christmas time.
08 F250 CC SB - too much to list
Big Thanks to:
Smokin' Guns Peformance and Accessories
Throttle Junkie Performance Parts
O2ShootTheJ is offline
post #12 of 22 Old 11-14-2009, 09:34 AM
ZeroOne's Avatar
Just saw another post about this. Similar, but with more info on WHY the switch failed. Here it is:
Originally Posted by BeatMarti View Post
I had the same problem. Replaced the pressure switch and it worked for a few hours, then it started again. It turned out that the wire harness connecting the pressure switch was "stressed" to the point that one of the wires got torn inside the insulation and stopped making contact. The pressure switch circuit (when open) reports "pressure on", hence, the cruise control will not come on.
I fixed the harness and all's well since.
ZeroOne is offline
post #13 of 22 Old 11-26-2009, 02:45 AM
Dealer replaced the brake switch under warranty. Drove from FL to NY no promblems now. Well the fuel economy sucks 12 mpg @70mph ave.
tomwaye is offline
post #14 of 22 Old 12-02-2009, 03:30 PM
fx4superduty33's Avatar
fixed my CC
finally got it fixed by the ford dealer last week, it was the second brake switch, after they replaced to 1st one over the summer, they r two brake switches, WTF FORD ? Anyways it has not messed up at all, i use it every time i drive, Finally im stoked
fx4superduty33 is offline
post #15 of 22 Old 07-03-2011, 07:46 AM
j21black's Avatar
Quoted: 15 Post(s)
My 2010 started doing this yesterday. Had a code for "brake line B" Cleared the code and still no dice. I figured it should come on if that code was not reading.
j21black is offline
post #16 of 22 Old 08-07-2011, 10:27 AM
wifordboyee's Avatar
just bought a 6.4 and mine doesnt work either! pissed off cause i plan on taking it on a 1800 miles trip this afternoon! gosh darn my poor foot
wifordboyee is offline
post #17 of 22 Old 01-08-2012, 08:29 AM
I have 2010 250 King Ranch with same problem, did they say how they fixed the brake pressure switch?
kingranchjr is offline
post #18 of 22 Old 01-21-2012, 05:55 PM
boostin's Avatar
happen to me also,did some digging,it is the connections to the switches,one is down by the brake pedal,other is under the hood by the brake booster,un plug them and reseat them will start working havent had a problem since.
2008 king ranch,4x4,quad captains,loaded,manual hubs,manual transfer case(hard to get),8"fabtech 4 link,20in mkw,37 nitto grapplers,mbrp duals
boostin is offline
post #19 of 22 Old 01-22-2012, 04:14 AM
FordFanatic83's Avatar
I have a 2008 f-250 with 75000 miles and mine stopped working along with my horn and radio buttons. Turned out to be the clock spring witch is not realy a spring but a coil of wires that looked like a clock spring hints the name "clock spring". Once i replaiced my old one i took it apart and the wires bound up in there and broke apart. Just in case anyone runs into this problem. I know all yalls sounds like the brake pressure switch.
FordFanatic83 is offline
post #20 of 22 Old 02-13-2012, 12:16 PM
Clock spring
How do I go about replacing the clock spring; about how much did it cost?
Feel free to call me @ 901.371.6437
Thanks man!
Spatel23 is offline
