Go Back   Ford Powerstroke Diesel Forum > Ford 08 and newer 6.4L Powerstroke Forums > 6.4 Electronics Discussion
6.4 Electronics Discussion TV's, Radios, everything electric and NON-Performance.
  #21 (permalink)
Old 08-14-2009, 10:32 PM
BrianR BrianR is offline
thanks guys for the info
  #22 (permalink)
Old 11-03-2009, 11:08 AM
scottiet61 scottiet61 is offline
There is a REALLY easy way to let you use the nav system while in motion.
Here are the instructions:
1. Take vehicle outside and agree to nav instructions. The gps needs to know its position.
2. Push hard nav button (on right side of radio). Go to your address book. Pick any of one of your saved addresses. Now that address is highlighted, look to right and push soft edit button. You will now see name of saved address.
3. Clear name of saved address and type in F-DEVELOP ON
(make sure to put space between DEVELOP and ON).
4. Now look to the upper left corner and you will see the word ADDRESS. Place your finger directly under the A and hold. If you do this right, the screen should change to the map screen.
5. Now push your hard menu button (on left side of radio). Across top of radio push soft SECURITY button. You have now entered security screen. You will see nothing in the right bottom most corner of nav screen. Push your finger and hold in that position till the screen changes.
6. You now have entered a parameter screen. Locate DRIVING RESTRICTIONS release. When you push the button it should change to driving restrictions stop. Exit the screen by pushing the soft BACK button.
7. Congrats you have just programmed your factory nav radio. NOTE: Every time you turn your vehicle off, you will need to repeat steps 5 & 6.
Good luck and enjoy. If you choose to monkey around with your other parameters, do so at your own risk. I will not be responsible for your dealer service call. This programming sequence should work for only the first generation navs. It will not work in the MY09, second generation. This has been used to reprogram many MY 07 and MY 08 Ford vehicles.
This is a free fix to want you want to do.
  #23 (permalink)
Old 11-03-2009, 03:06 PM
navydocsuperduty navydocsuperduty is offline
scottiet61 i love you man, just did this for my nav unit in the 08 it works and the steps you must do upon starting the truck are easy as anything. works like a charm.
  #24 (permalink)
Old 11-03-2009, 03:07 PM
A8050266 A8050266 is offline
Send a message via AIM to A8050266 Send a message via MSN to A8050266 Send a message via Yahoo to A8050266
Scottie61,
This crack/Hack secret has been a long time coming!!!!
SUPER THANKS!!!!
  #25 (permalink)
Old 11-03-2009, 03:14 PM
Glad to hear I could be of help! It's so easy huh.
