Go Back   Ford Powerstroke Diesel Forum > Ford 08 and newer 6.4L Powerstroke Forums > 6.4 Electronics Discussion
6.4 Electronics Discussion TV's, Radios, everything electric and NON-Performance.
  #11 (permalink)
Old 08-09-2009, 03:34 PM
ttwndoc ttwndoc is offline
works very well. I have had it for about 3 weeks. It is an awesome little product.
  #12 (permalink)
Old 08-10-2009, 04:03 AM
Tarheel_6.4L Tarheel_6.4L is offline
can somebody post a link so i can view this product? Sounds like a nice birthday gift to myself.
  #13 (permalink)
Old 08-10-2009, 06:42 AM
BigKid BigKid is offline
I googled it, this is what I found. FORD 360 LOCKPICK
  #14 (permalink)
Old 08-11-2009, 06:16 PM
A8050266 A8050266 is offline
Send a message via AIM to A8050266 Send a message via MSN to A8050266 Send a message via Yahoo to A8050266
sweet... where was this when I modded my nav?
  #15 (permalink)
Old 08-11-2009, 06:51 PM
I'm loving it!!!!!!
  #16 (permalink)
Old 08-12-2009, 09:45 AM
FiveFlat FiveFlat is offline
Originally Posted by BrianR View Post
Does the Lock Pick work on '08 nav systems (non sync)?
This is what I'm confused about as well. I don't think the '08 super duty nav systems are "sync" systems...
  #17 (permalink)
Old 08-12-2009, 10:08 AM
Owning an 08 with the nav system (which has been modified some many months ago.) Its deff not a sync unit. nor is it compatible. I dont believe this will work on our setup (the NAV bypass) but if you find something that does.
sign me up. I found a temp solution called "BRAKES" use them when needed.
  #18 (permalink)
Old 08-13-2009, 08:23 AM
It will work on the 08 non sync. That is what I have. I have the nav/ audiophite system with rear entertainment system. It works well.
  #19 (permalink)
Old 08-13-2009, 10:01 AM
So are you saying it bypasses the pull over and enter Address info
so you can do it while traveling over 5mph?
  #20 (permalink)
Old 08-14-2009, 07:16 AM
Harley350 Harley350 is offline
There are two Ford lockpicks to chose from.
For the 08 you will want the "non hard drive" version works with or without SYNC (some 2008 Fords did come with SYNC just not the Superduty, keep in mind if you have SYNC you will need the hard drive version)
FORD 360 LOCKPICK
For the 09 you will want the "hard drive" version. Works with or without SYNC (this version has not been released yet)
HARD DRIVE LOCKPICK
