Go Back   Ford Powerstroke Diesel Forum > Ford 08 and newer 6.4L Powerstroke Forums > 6.4L Problems Forum > 6.4 Drivetrain Problems
  #11 (permalink)
Old 05-22-2009, 12:07 PM
FX4STROKER FX4STROKER is offline
<--- COOL NAME
Originally Posted by Dave View Post
That being the case its entirely possible you knocked a couple teeth out of the pinion gear
oh wonderful! It sounds like a old race car with a locker
  #12 (permalink)
Old 05-22-2009, 12:08 PM
Cody6405 Cody6405 is offline
Originally Posted by FX4STROKER View Post
its a loud poping noise
Oh... um yeah... you might want to get that checked out
On a seriuos note sounds like maybe somthing with the spider gears. If it was just a shudder i had a truck that had worn limited slip clutches and it used to shuder when i would turn but never made any audible popping noises.
  #13 (permalink)
Old 05-22-2009, 12:10 PM
<--- COOL NAME
Yeah this was poping and woould kinda jerk the truck but it only does it when I turn.
I dont know much about these rear ends but could it be possible the posi is locked and maybee stuck?
  #14 (permalink)
Old 05-22-2009, 01:02 PM
dzchey21 dzchey21 is offline
does the inside tire drag when you turn like its got a spool or something?
  #15 (permalink)
Old 05-22-2009, 01:25 PM
RedDye01 RedDye01 is offline
id buy three quarts of diff oil and pop that cover off asap before you grenade that whole thing. At least if a tooth is busted off you can take out the debris and get it fixed, but if there is something bouncing around in there and it manages to wedge itself between a ring gear and a hard place.....
  #16 (permalink)
Old 05-22-2009, 02:32 PM
yeah i agree. if you blow the housing apart, well ford wont be happy
  #17 (permalink)
Old 05-22-2009, 03:07 PM
Big Tone Big Tone is offline
Talked to a guy the other day, said he has been blowing limited slip clutch packs in his 08. He is a hot shoter that pulls 30k, but its possible you did the same.
  #18 (permalink)
Old 05-22-2009, 03:31 PM
<--- COOL NAME
Ill pull the diff cover and check it out. anyone recomend any diff fluid?
  #19 (permalink)
Old 05-22-2009, 04:06 PM
2005F250 2005F250 is offline
I've broken teeth off a ring gear before. The way I figured out something was wrong was that the truck smelt like gear oil and the whole underside of the truck behind the axle was covered with oil.
  #20 (permalink)
Old 05-22-2009, 06:39 PM
<--- COOL NAME
OK everyone heres an update. I pulled the diff cover and everything looks good. The gear oil did look alittle milky and seemed kinda thin. I put mystic gear oil in and put new rtv. took it on a drive and its not poping anymore when I turn. But its whineing like its tight but it only does that when I turn. Any ideas now
