4x4 Not engaging - Ford Powerstroke Diesel Forum
post #1 of 9 Old 03-31-2014, 08:32 PM Thread Starter
4x4 Not engaging
I'm having the same issue with my 4x4 that some of you guys are having except my vacuum lines are either cracked or broken. Is there any other alternative than the ford vacuum lines, maybe something not so brittle?
Tonka88 is offline
post #2 of 9 Old 04-01-2014, 06:08 PM
Ford makes those vacuum lines out of kiln dried twigs and glass.
Scumbag is offline
post #3 of 9 Old 04-30-2014, 09:38 PM
D HD's Avatar
Im thinking im having the same problem. What did u end up fixing it with?
D HD is offline
post #4 of 9 Old 05-22-2014, 12:22 PM
rocknmj's Avatar
DieselSite has some braided steel replacements for those. I have a set I haven't put on yet. But they only replace the rubber portion that goes into the back of the hub...not all the plastic line behind. Not sure how often that breaks. From what I understand it is usually the rubber sections that go bad.
Sent from AutoGuide.com App
2008 Lariat 4x4 CCLB DRW
H&S Mini, S&B Intake
AirDog 2, Beans Diesel Sump
DieselSite Coolant Filter, CAC Boots, Tranny Filter
rocknmj is offline
post #5 of 9 Old 05-25-2014, 12:55 PM
groove's Avatar
just discovered my 4x4 didn't engage..t ook 6hrs to dig it out and then I realized there are manual hub locks behind the wheel caps. doah!
applied vacuum to hubs and its not holding so I am lead to believe its the seal in the hub that has gone south. Anyone ever replace these?
08 F350 CCSB 4x4 01/07 Job 1
0.030" de-lipped slugs, 70+ atmosphere turbo, ARP studs, Mild Ported Heads (w/bronze guides), Flo-Pro EGR Delete
Mini Maxx Race tuner, AFE exhaust turbo back, S&B Intake, Sinister coolant filter
Lifted nicely on 20" wheels
groove is offline
post #6 of 9 Old 05-25-2014, 12:56 PM
ZMANN's Avatar
Quoted: 1346 Post(s)
yes last weekend '
have fun
We Miss you Ronnie
ZMANN is online now
post #7 of 9 Old 05-25-2014, 01:16 PM
ZMANN's Avatar
I don't know what effects the plastic lines more for some than the others ?
I live in AZ I park outside and I still have OEM lines at 100k
We Miss you Ronnie
ZMANN is online now
post #8 of 9 Old 05-25-2014, 08:09 PM
jeremyfoy80's Avatar
We drive $50,000 trucks, and they build them with the cheapest crap they can find!
jeremyfoy80 is offline
post #9 of 9 Old 05-26-2014, 06:22 AM
travisH3's Avatar
Quoted: 2 Post(s)
Feedback Score: 13 reviews
my lines are fine but my actual hub isnt holding the vacuum. the its leaking out of the back side of it so in order to replace that seal you have to pull the whole hub apart and the axle out. it sucks. so i just use mine as manual hubs lol
T-rav
2010 F350 6.4-
s467 MPD single kit, H&S Jesse Byall tuning, No limit IC piping and intake,mishimoto intercooler, MPD billet CCV/oil filler, FASS with sump, SOTA A.W.O.L. polished wheels, toyo rt tires, RED Newton traction bars, oem projector retrofit and a bunch of LED lights LOL
Holderdown Performance #teamHDP
OUR FLEET: 2015 f450, 2014 Platinum F350, 2012 F450 6.7, 2010 F350 6.4, 2005 F350 6.0, 04 F450 6.0
travisH3 is offline
