New lift - vibrations - drive shaft angle? - Ford Powerstroke Diesel Forum
post #1 of 11 Old 03-20-2014, 08:39 PM Thread Starter
Recently I added a leveling kit in the front and blocks in the rear on my 09 f250. The truck already had an 8" suspension lift on it. I did replace my track arm and now I am noticing vibration during acceleration. It goes away at 20mph and gets loud at 60mph
Do I have an issue with my drive shaft angle? Is this an easy fix?
Thanks.
juicefree is offline
post #2 of 11 Old 03-20-2014, 09:01 PM
srjd's Avatar
Quoted: 2 Post(s)
Your not going to want to hear this but lift it properly. Adding a leveling kit to a lift is almost always asking for issues
01/07 Job 1 F350 H&S Tuned. ARP Studs, AFE 4'' straight pipe, EGR delete with elbow, AFE stage 2 CAI, 6'' lift on 37s, 20x12 Fuel Nuts two piece, Sinister coolant filter, CCV Mod, Projector headlights HID kit
srjd is offline
post #3 of 11 Old 03-21-2014, 03:24 AM Thread Starter
The truck is running great and rising fine other then the vibration. I spoke to a few companies who do lifts and said that it's not an issue to add the leveling kit as long as I adjusted the front end which had been done. I have read that adding the lift could cause the vibration and noise that I am hearing which I am wondering if that's the drive shaft angle that needs to be adjusted.
post #4 of 11 Old 03-21-2014, 07:13 AM
Quoted: 2 Post(s)
carrier bearing needs to be adjusted for the new drive angle. get some spacers and drop it down a bit. you might need to get longer bolts to do this. you'll just have to play with it a few times until the vibration goes away. I wouldn't drive it too much until you get it worked out.
Kris
2008 Ford F250 6.4L Crew Cab Short Bed King Ranch
3.5" ReadyLift Leveling Kit, 37x13.5x20 Toyo MT's on stock 20's, Dual Steering Stabilizer, Livewire w/ IDP, KEM, Gearhead, S&B, 5" Flo-Pro, Rudy's EGR Delete and Cold Side Pipe, CCV
p8ntballn2 is offline
post #5 of 11 Old 03-21-2014, 07:16 AM Thread Starter
Thanks, Kris. I have only driven it less than 10 miles. I am going to run it by the mechanic this morning and let him know. Hopefully he has the materials at his shop to handle this for me.
I have read a bunch of stories when the lift goes above 4" it can begin causing this problem and it doesn't appear to be a major fix. I appreciate your feedback.
post #6 of 11 Old 03-21-2014, 09:12 AM
ZMANN's Avatar
Quoted: 1473 Post(s)
spacers only lower the carrier but don't angle it properly
We Miss you Ronnie
ZMANN is online now
post #7 of 11 Old 03-21-2014, 09:15 AM
ZMANN's Avatar
you want something like this ideally otherwise the carrier bearing isolator takes a beating
and it easier to fine tune
One Up Offroad Drive Line Drop
We Miss you Ronnie
ZMANN is online now
post #8 of 11 Old 03-21-2014, 09:16 AM Thread Starter
The driveshaft that is currently on the truck is a two piece drive shaft . I dropped the truck off this morning and he is going to measure the angles and probably need to add some shims.
I crawled under the truck this morning and learned that it was a two piece drive shaft which looks like it was added when the lift was put on. Hopefully he can get the parts needed today and correct the issue.
post #9 of 11 Old 03-21-2014, 09:19 AM Thread Starter
This is nice! He is going to give me a call this afternoon and let me know how much the angle is out. I'll be sure to mention this part.
Thank you for your help, ZMANN
post #10 of 11 Old 05-19-2014, 10:32 AM
Thats a nice part and a fair price too. Im going to look into my driveshaft angle. I have slight vibration above 60mph. I was just thinking its my tires. I do have a 6" lift.
Thanks for the link
2008 F350 King Ranch 6.4L , 6" RC lift, SCT Livewire Extreme
zpi28 is offline
