Rear backing plates are shot!!! Help me fix them!!! - Ford Powerstroke Diesel Forum
post #1 of 7 Old 12-31-2013, 12:38 PM Thread Starter
Send a message via Yahoo to skipnay
The backing plates that hold the emergency brake pads are shot. One is about to break and the other backing plate where the pin holds the pads has a hole there the size of a quarter. So where did you guys get the parts and what special tools do I need? Parts are over $360 for each side from Ford. They don't sell the backing plates seperately!!! This really sucks and while I'm doing it I have one axle seal leaking so I will just replace both while I'm at it.
I have the extended warranty but it doesn't cover rust or wear and tear items. They would work with me on the price but I'm figuring I can do it just as good as then can for $115 an hour. So what kind of rear axle fluid will I need then also?
2010 My Wife has 2 Full time JOBS NOW
2008 F250 H&S MiniMaxx, S&B CAI, and cat/pdf delete
2008 Brute Force 800 All hooked up 67hp to the wheels
2007 Got Married
2004 KFX 700 Stock Bore Kit XX cams
1990 Mustang Notch getting ready to hook it up
1988 Mustang GT 449hp to the wheels 6sp Getting a cage installed
skipnay is offline
post #2 of 7 Old 01-04-2014, 06:57 AM Thread Starter
Your telling me I'm the only one that has ever had this problem?
2007 Got Married
skipnay is offline
post #3 of 7 Old 02-16-2014, 06:55 AM
Powerstroke Techie
http://www.summitracing.com/int/part...250-super-duty
Boom.
Just saved you $540.
Ford Senior Diesel Technician
2008 F-350 4x4 Off Road 6.4 Powerstroke Diesel
There are strange things done 'neath the midnight sun by the men who moil for gold.
The arctic trails have their secret tales that would make your blood run cold.
Big Angry Hillbilly is offline
post #4 of 7 Old 02-16-2014, 07:16 AM
ars5147's Avatar
Quoted: 116 Post(s)
Originally Posted by Big Angry Hillbilly View Post
Yep, Dorman makes good replacements. I had this problem on my 6.0. Found the Dorman part # and took it to a local parts store and they ordered them.
RockAuto Parts Catalog has them too
Go back to Ford and tell them to shove it.
Rear will be 75w-140 synthetic and friction modifier. Most likely you won't lose that much gear oil. Pop the hub off and jam a rag in the axle tube to keep it from dripping.
Edit: Just looked at the original post date, hopefully you got it taken care of by now.
2008 F250 CCSB 6.4
1997 F350 CCLB 7.3
2011 F150 SVT Raptor
ars5147 is offline
post #5 of 7 Old 02-17-2014, 03:06 PM Thread Starter
You guys are AWESOME. I even looked at summit but I guess I was putting in the wrong thing to search. I just haven't been using the emergency brake and haven't had any problems yet. I do want to get these done once snow stops flying...
2007 Got Married
skipnay is offline
post #6 of 7 Old 02-17-2014, 05:52 PM
ars5147's Avatar
Quoted: 116 Post(s)
Good, it's not that hard at all to do. Look and see if you get new pins (the ones that hold the shoes to the backing plate) with the plates. I think I got them when I did my 6.0. But if you don't, sometimes the flattened end of the pin is rusted off and can't be reused.
2008 F250 CCSB 6.4
1997 F350 CCLB 7.3
ars5147 is offline
post #7 of 7 Old 02-25-2014, 07:20 PM
Powerstroke Techie
The last set of Dorman plates I got came with the pins, but if you're in that far and things are dickered, you might as well change out the hardware, shoes, and pivots as well.
