Go Back   Ford Powerstroke Diesel Forum > Ford 08 and newer 6.4L Powerstroke Forums > 6.4L Problems Forum > 6.4 Drivetrain Problems
Old 08-20-2008, 08:39 AM
DSL_PWR DSL_PWR is offline
TPMS psi ?
At what PSI is this thing supposed to come on? Reason I ask is that mine did come on the other day and all tires were above 58 psi (fronts 58 psi and rears 60 psi). I thought that I read somewhere that it was 55 psi which is what the computer was set for? Is this incorrect?
Old 08-20-2008, 08:59 AM
Pahrump Pahrump is offline
I think it depends more on what the original PSI the stock tires were supposed to be....I dont think its set the same for every truck.
Old 08-20-2008, 09:13 AM
krazeehorse krazeehorse is offline
2 to 3 psi variation in gauges isn't unheard of either.
Old 08-20-2008, 02:31 PM
Ok, thanks...
Old 12-21-2008, 02:08 AM
105thHDSUPERDUTY 105thHDSUPERDUTY is offline
My truck is supposed to be set at 65/65 but the factory set it at 50/80 as if I had ordered the camper package, it should tell you on the door jam.
Old 12-21-2008, 03:41 AM
sikktruk01 sikktruk01 is offline
not sure on the ford. but the toyota's have a sensor in the spare also. it may be low causing your tpms light.
Old 12-21-2008, 05:02 AM
cobraracing cobraracing is offline
mine came on when the temps dropped to below -20
I checked the tires and they were all at 45 PSI, I only have 500 miles on it and can only assume the guy doing the PDI didn't adjust the pressures
Old 12-23-2008, 08:50 PM
FX4STROKER FX4STROKER is offline
COTTONWOOD CREEK RANCH
Thats really low for E range tires. I run 60 all the way around.
Old 12-24-2008, 03:12 AM
That is what i adjusted the pressures to cold
Old 12-24-2008, 12:52 PM
gotcha I dont have to worry about it gettin that cold here in oklahoma.
