One tire Fire :) Fluid dirty or clutches bad - Ford Powerstroke Diesel Forum
post #1 of 13 Old 08-29-2013, 03:17 AM Thread Starter
Is there anyway to tell if my limited slip rear end is actually working? Should both tires spin when taking off or does it always leave a "one wheel burnout".
I was trying to test my EGT sensor last night and while doing so in my driveway i powerbraked the truck to get the exhaust temps up and while doing so, only one wheel broke loose in the gravel when the breaks gave way. I realize that they are not true posi track rear ends but any info is appreciated.
Also its about time to flush/fill the fluids on the front and rear diffs. Anyone know of a proceedure to do the rear diff? Is the gasket reusable or is it a "make your own out of blue silicone" type? Also what is good to use to flush the rear end? How much friction modifier do you add? I think the bottle is 8oz but do you add the whole thing?
ANy way to tell if the clutch packs in the rear end are bad?
Thanks,
08 JOB 1 F-250 Lariat Crew Cab, S&B INTAKE, H&S Blk MAXX, 5" Flo PRO, EGR Delete, Air Dog 165, Upgraded Bellows, MBRP Intercooler pipe, 4" Down pipe, Tial Wastegate, OUO T bars, ARP studs, Bestop pwrbrds
***Legal Disclaimer: Anything I say about my vehicle on this website(Powerstroke.org), pertaining to modifications, is only to gain acceptance from my peers, and does not actually represent anything actually existing on my truck, and thus, cannot be held against me in any issues.
08smoker08 is offline
post #2 of 13 Old 08-29-2013, 09:54 AM
Depends how fast that wheel was spinning. If it wasn't enough to lockout the limited slip engagement, it won't do anything. Typically on limited slip, you'll have a one wheel burnout for some distance, then both will engaged.
Expirobo is offline
post #3 of 13 Old 08-29-2013, 10:22 AM
Quoted: 47 Post(s)
2015 F350 DRW Platinum, SCT X4, EDGE CTS2, aFe PDS, AirLift 5000 Ultimate & Wireless Air, Lund LED Bull Bar, RC Grille bar, B&W 5th Wheel, Stark LED Lighting
2010 F250, H&S Mini Maxx, aFe PDS, Diamond Eye 4", Pro Comp Nitro 2.5", Bilstein 5100, Westin Bull Bar, Bushwacker Pocket Style, B&W Slider, Firestone Ride-Rite, Fuel Hostage 20x10, Pioneer/Kicker/JL Audio
RUFFSTUFF is offline
post #4 of 13 Old 09-03-2013, 02:40 AM Thread Starter
thanks for the input guys,
post #5 of 13 Old 12-24-2013, 10:13 AM
Originally Posted by RUFFSTUFF View Post
The Eaton G80 in the video is not a limited slip differential. This is an automatically locking differential. This is exclusive to GM, and is not offered on Ford vehicles.
2008 Ford F-250 6.4l Powerstroke, crew cab, 4x4
2013 Jeep Wrangler JK Unlimited, 2.5" lift
1978 Jeep CJ-7, 304 V8, 3 speed manual, 4" lift, 33's
Foulplay is offline
post #6 of 13 Old 12-25-2013, 02:59 AM
Quoted: 47 Post(s)
No kidding. I posted it for the examples of a limited slip in operation, which is clearly shown... Thanks.
post #7 of 13 Old 12-25-2013, 07:35 AM
How much does it take to fill rear?
2006 Ford Powerstroke Super Cab 4x4 auto 120K bulletproofed
ramz trk is offline
post #8 of 13 Old 12-25-2013, 07:49 AM
Colin7.3's Avatar
It tells you in your owners manual
Colin S. Age:22 Certified Diesel Tech, Infantry US ARMY
E99 7.3 6spd 4x4 6637, 4" straight pipe, 365,000 miles
"wear your high mileage as a badge of honor"
04 GMC 2500 4x4 Duramax/Allison
Colin7.3 is offline
post #9 of 13 Old 01-04-2014, 04:27 PM
My apologies. Guess I misinterpretted where you were going with that.
Foulplay is offline
post #10 of 13 Old 01-04-2014, 04:37 PM
Quoted: 47 Post(s)
No problem. It's all good. Hopefully it helps some.
