4x4 auto not working - Ford Powerstroke Diesel Forum
post #1 of 9 Old 06-21-2013, 12:18 PM Thread Starter
dieseltruckin's Avatar
So I needed to use 4x4 today, and you guessed it, not working. So here is my problem, I have the auto/manual hubs. When it wouldn't lock in, I went to manually lock them, could only turn the hubs partially by hand. Put a pair of pliers on them (scratched the plastic coating) and turned them the rest of the way to lock position. It works in that configuration. So it's gotta be in the auto system. Anybody have any ideas? Also, any ideas to make the hubs easier to turn by hand???
'08 250 Lariat 4x4 c/c s/b
H&S Mini Max
Cat/dpf delete
S&B Cold Air
dieseltruckin is offline
post #2 of 9 Old 06-22-2013, 04:04 AM
powercho's Avatar
My auto hubs didn't lock after a cab off so I checked to make sure the vacuum pump was running while the 4x4 is engaged. Traced each tube that runs to the hubs and found the pass side was never reconnected. Connected it and fixed the issue.
Not sure about the tight hub deal, but interested about a solution.
powercho is offline
post #3 of 9 Old 06-22-2013, 05:01 AM
taskforcefreddy's Avatar
Two things:
1. 99% of the time, you have a vacuum leak and must trace your vacuum lines as powercho mentioned.
2. These hubs are not of the greatest quality however it's possible to pull and re-lube them to get more life out of them. Also keep in mind that when it comes to manually locking hubs, they're kind of like a diesel generator. You gotta work it to keep it working. What I mean by this is that go ahead and lock them in every once in a while to keep them 'loose'. Am guessing that the next time you try locking them in manually, it won't be so difficult.
Do a youtube search to learn how to re-lube the hubs. It's really simple.
taskforcefreddy is offline
post #4 of 9 Old 06-22-2013, 06:01 AM
ZMANN's Avatar
Quoted: 1564 Post(s)
Those are Warn hubs
and the only option unless you spend a grand to eliminate the Auto hub and unit bearings
it takes a few minutes to pull and lube and as mentioned they like to be exercised
if they need replaced E bay seems to always have new ones at the best $$
We Miss you Ronnie
ZMANN is offline
post #5 of 9 Old 06-22-2013, 06:19 AM Thread Starter
Thanks guys. I checked my vacuum pump and it is working. I'm gonna check the lines down to each hub today. And I'm going to pull the hubs and repack them. Hope I don't screw anything up, lol.
H&S Mini Max
Cat/dpf delete
S&B Cold Air
post #6 of 9 Old 06-22-2013, 06:53 AM
asian195's Avatar
Quoted: 2 Post(s)
Pull the hose from one hub at a time. And check if your 4x4 engages each time. The unit bearing itself has O-rings that tend to leak..
2003 F-350 6.0L.
Leveling kit
35/12.50-20 Federal Couragia M/T
20x10 black Fuel Hostage wheels
4"-5" exhaust no cat
Airaid intake
SCT tuner-awaiting custom tune
Edge Insight CTS
Blue spring
6.4 Banjo bolts
Zoodad mod
EGR Delete
ARP Head Studs
To Do/Wish list:
FICM tune
BPD Oil Cooler/Filter
Fog light mod
Harpoon mod
Injectors 155cc
asian195 is offline
post #7 of 9 Old 06-22-2013, 03:18 PM Thread Starter
Hubs were froze up. Cleaned and packed full of grease and seem to work fine now.
H&S Mini Max
Cat/dpf delete
S&B Cold Air
post #8 of 9 Old 06-22-2013, 07:47 PM Thread Starter
Well, I was wrong. They worked great after I put it back together. Went out tonight, dinner, driving around for a while and thought I should just check, hit the switch and nothing happened. I can here the transfer case lock, hear the vacuum pump, light comes on the dash, but hubs won't lock. Try manual and they lock in nice and smooth. Is there any other actuators that could be getting hot after driving and not functioning? It's dark now, but tomorrow ill be checking vacuum lines too. This is aggrevating.
H&S Mini Max
Cat/dpf delete
S&B Cold Air
post #9 of 9 Old 06-24-2013, 01:43 PM Thread Starter
Ok, I've got good vacuum to here. Nothing after though. Middle wire has bat voltage, left wire has bat voltage when 4x4 engaged, right wire has almost no voltage at any time. Doesn't seem to be a ground either. I would like to make sure its this switch before I replace it.
ID:	129506   Click image for larger version
H&S Mini Max
Cat/dpf delete
S&B Cold Air
