Stupid 4wd - Ford Powerstroke Diesel Forum
post #1 of 23 Old 06-21-2013, 09:50 AM Thread Starter
preston77's Avatar
Stupid 4wd
4wd won't work. I've tried the hubs in auto and lock, checked the vacume line and I can hear something engaging when I turn the 4wd knob inside. Am I missing anything else to check?
preston77 is offline
post #2 of 23 Old 06-25-2013, 04:31 PM
Are you sure it's not working? Have you tried high and low?
Burner5509 is offline
post #3 of 23 Old 06-25-2013, 04:50 PM Thread Starter
preston77's Avatar
I figured it out. The vac line had a hole in way at the top where it had rubbed so auto wouldn't work and the jackwaggon that was locking the passenger side was turning it the opposite way. It was the 1st time I tried 4wd so I just assumed it was in auto on both sides but they were flip flopped.
post #4 of 23 Old 07-07-2013, 11:25 AM
Quoted: 45 Post(s)
Where is the vacuum line...? I'm having the same problem just now. Can't get 4Hi or 4Lo unless I engage the hubs manually. If I leave the hubs in AUTO, the front wheels do not drive from the switch...
2015 F350 DRW Platinum, SCT X4, EDGE CTS2, aFe PDS, AirLift 5000 Ultimate & Wireless Air, Lund LED Bull Bar, RC Grille bar, B&W 5th Wheel, Stark LED Lighting
2010 F250, H&S Mini Maxx, aFe PDS, Diamond Eye 4", Pro Comp Nitro 2.5", Bilstein 5100, SmittyBilt Bull Bar, Bushwacker Pocket Style, B&W Slider, Firestone Ride-Rite, Fuel Hostage 20x10, Pioneer/Kicker/JL Audio
RUFFSTUFF is offline
post #5 of 23 Old 07-08-2013, 02:47 AM Thread Starter
preston77's Avatar
It's on top of the front axle on the driver side. It'll be a small black 3/8 hose.
post #6 of 23 Old 07-08-2013, 04:40 AM
Quoted: 45 Post(s)
Thanks, I'll check it out.
post #7 of 23 Old 07-08-2013, 05:15 AM Thread Starter
preston77's Avatar
No problem. If ya can't find it I'll post a pic later for ya when I get home and can upload a pic from the computer
post #8 of 23 Old 07-08-2013, 05:22 AM
Quoted: 45 Post(s)
Cool. Thanks again.
post #9 of 23 Old 07-12-2013, 04:26 PM
Quoted: 45 Post(s)
So here's what I know (and it's not very much):
When switching to 4WD Hi, the light comes on steady, doesn't flash but does for 4WD Low.
When switching to 4WD, there is a pump on the driver's side by the degas bottle that runs continuously for a minute or 2 then shuts off. Does the same every time you cycle the ESOF switch.
There is a distinct sliding/clunk sound from the front wheels when cycling the ESOF switch.
None of the vacuum lines look obviously damaged.
I have not checked any fuses yet.
I can still manually engage the hubs.
post #10 of 23 Old 07-12-2013, 04:32 PM
Big_Smokey's Avatar
Quoted: 9 Post(s)
Mine was vacuum lines. Only worked when locked into manual lock
Big_Smokey is offline
