08 f350 4x4 shuddering on take off after lowering it - Ford Powerstroke Diesel Forum
post #1 of 7 Old 05-08-2013, 09:03 PM Thread Starter
( i know i know why lower a 4x4, but its my truck and its the only way it fits in the garage until i get my house with a shop again.
my truck when i bought it a month ago had a leveling lift in the front, rear is stock.
so i took the rear blocks out of the back of my truck yesterday and took it around the block it seemed to be fine, no problems at all, then today i lowered the front by taking the leveling kit out and taking a half an inch off the front springs to make it level and not its shaking in the rear end when i take off all the way to almost 25mph but only when your on the gas. i tried to take off slowly to make sure i wasnt getting some kind of axle wrap with no blocks but it still shakes.
any ideas on what it could be??
skid_strokin951 is offline
post #2 of 7 Old 05-08-2013, 10:58 PM
GregsSD's Avatar
Quoted: 15 Post(s)
Garage
When you took out the rear blocks the angle of the driveshaft changed. The vibration is most likely coming from your driveshaft carrier bearing or u-joint.
You may have to have some custom work done to move the carrier bearing higher so that the angle is not so far off.
2005 F-250 CC/SB 4x4 medium wedgewood blue
5" lift, 5" Donahoe rear springs, 35x13.50 MTZ's, 18x12 Fuel Hostage wheels, 4.30 gears, Banks 4" exhaust, Airraid intake, SCT from Innovative, ARP headstuds, Bulletproof ficm, Bulletproof EGR cooler, Scangauge II, Randy Ellis Design lightbar, Street Scene flares, Harpoon mod, Zoodad mod, LED 2010 taillights, Switchback LED front turn signals
GregsSD is offline
post #3 of 7 Old 05-08-2013, 11:17 PM
atvrider93's Avatar
Quoted: 8 Post(s)
I may be wrong but i think you have to have some sort of block there. Agree with changed angles of driveshaft, you may even have to shorten.
1996 F350 4x4 CCLB-- I'll miss her
1996 F350 4X4 RCLB zf5 213K
6637
OBA w/horn
DE 5"
PHP tunes
Mud Country 315/75/16
2008 Wr250X
Originally Posted by belz View Post
There u go Tom. John may not be sexy, but he can tutor you, lol.
atvrider93 is offline
post #4 of 7 Old 05-09-2013, 04:28 AM Thread Starter
thats what i was thinking was the angle was off, i crawled under it late last night, i dont have a measurement on the drive shaft yet but its angled down to the carrier bearing an then is flat 0* back to the rear axle, ive seen allof worse angles not shake or anything but this truck is different i guess.
i havent been able to find any kits to lift it so im thinking ill make my own out of square tubing, the stock drop is 3" so im thinking im going to try a 1" lift on the carrier bearing to start out with and see what it does
post #5 of 7 Old 06-18-2013, 01:29 PM
Zachf's Avatar
how did this turn out?
08 F-350 6.4 Lariat FX4 ccsb, southbend single disk, Spartan, egr delete, 4" turbo back, afe intake
Zachf is offline
post #6 of 7 Old 08-12-2013, 06:12 AM
fordfish's Avatar
are you putting the shim under the carrier bearing, I have this problem and I think its the front ujoint
08 6.4 Lariat 350 CC DRW 4x4
Afe Stage 2 Si
Spartan DD
Bed Cover
Ford "Factory" Duals
fordfish is offline
post #7 of 7 Old 08-12-2013, 10:11 AM
Did it do the shuddering when you removed the rear blocks? Or after you did the front? That should help narrow it down.
Expirobo is offline
