front driveshaft u-joint ?. Replace with factory or not? - Ford Powerstroke Diesel Forum
post #1 of 2 Old 03-22-2013, 02:36 AM Thread Starter
Took the front 4wd shaft off last night to grease the slip joint. Had all the new bolts and straps there ready but after playing with the u - joint a bit it seems that it needs to be changed as well. It has a little bit of a catch in it when moving it back and forth.
So my ? is do i replace with factory or aftermarket. If aftermarket, what brand? Hoping to fix this tomorrow.
Thanks all,
08 JOB 1 F-250 Lariat Crew Cab, S&B INTAKE, H&S Blk MAXX, 5" Flo PRO, EGR Delete, Air Dog 165, Upgraded Bellows, MBRP Intercooler pipe, 4" Down pipe, Tial Wastegate, OUO T bars, ARP studs, Bestop pwrbrds
***Legal Disclaimer: Anything I say about my vehicle on this website(Powerstroke.org), pertaining to modifications, is only to gain acceptance from my peers, and does not actually represent anything actually existing on my truck, and thus, cannot be held against me in any issues.
08smoker08 is offline
post #2 of 2 Old 03-24-2013, 06:45 AM
ryandamo's Avatar
i would try to put ones with grease fittings on them so you can drive out moisture with new grease since its only a part time shaft.
2016 F450 6.7L XLT 4x4Dump, bone stock
1994 F250 7.3L XLT 4x4 ZF5 , Centurion, 4" Lift, 6637, Gulf Coast Bypass Filter, Big fuel tanks, dana 60 swap, No longer dually
1997 F350 7.3L XLT 4x4Dump, E4OD, 4 in exhaust, TS 6 position, 3/8 Trans line+external filter
2013 Scag Turf Tiger 61" 1.1L Caterpillar Diesel
1960 John Deere 440 Backhoe 2-53 detroit
ryandamo is offline
