Go Back   Ford Powerstroke Diesel Forum > Ford 08 and newer 6.4L Powerstroke Forums > 6.4L Problems Forum > 6.4 Drivetrain Problems
Old 12-12-2007, 10:05 AM
aRibelin aRibelin is offline
ABS failure
Truck failed to stop while driving in a snow storm last weekend. Pedal went to the floor as I was sliding out into the intersection and the ABS light came on. The light came on/off throughout the day; then stayed off and the truck appeared to function correctly. The dealer found an ABS failure code and they replaced the rear ABS sensor.
Old 12-12-2007, 10:20 AM
lifewitlooie lifewitlooie is offline
COLLEGE KID
Send a message via AIM to lifewitlooie
I would try and take it easy for a little while, see if u can replicate the problem
Old 12-12-2007, 10:38 AM
Rob Rob is offline
Free Faller
Send a message via AIM to Rob Send a message via MSN to Rob Send a message via Yahoo to Rob Send a message via Skype™ to Rob
yeah, seems like alot of the ABS stuff coming around with alot of different vehicles. sorry about your troubles, but im glad you werent in a accident. let us know if anything else comes up with the ABS stuff.
Old 01-02-2008, 08:50 AM
Sailcofc Sailcofc is offline
I have an intermittent ABS problem too. Had an emergency stop situation and locked up the rear tires resulting on a flat spot. Replaced the four rear tires at 2500 miles for more than $1000 because the dealer could not find anything that said that the ABS malfunctioned. Didn't happen for a while but returned recently. Took it in again and the Dealer found a code this time. They ordered a new sensor but due to timing I had to leave. Took it in to another dealer in the town where I went (and had the light come on between dealers) but the second one could not find anything wrong with it so no sensor/fix here.
Anyways, just another problem to add to the list.
