Go Back   Ford Powerstroke Diesel Forum > Ford 08 and newer 6.4L Powerstroke Forums > 6.4L Problems Forum > 6.4 Drivetrain Problems
Old 11-29-2007, 09:54 PM
lherronjr lherronjr is offline
Vibration/Shudder
Is anyone having a vibration or shudder while driving. I am having a fit trying to get the dealer to find the problem. They keep messing with drive line angles and pinion angles but have not gotten completely rid of it. Hopefully someone can assist.
Thanks, Larry
Old 11-29-2007, 10:24 PM
Raul@Stealth Automotive Raul@Stealth Automotive is offline
does it happen at all speeds? could be a balance issue on the tires.....
Old 11-29-2007, 10:33 PM
Yes, I wondered the same but was thinking more along the lines of a out of round shaft. They disconnected the rear wheels from driveline once put in four wheel drive and drove in front wheel drive and said the vibration was gone. I think its a bad drive shaft possibly.
Old 11-29-2007, 10:45 PM
i think your right.... have they even tried changing the rear driveshaft?
Old 11-29-2007, 10:51 PM
No, they have just shimmed, wedged and changed carrier brackets
Old 04-07-2008, 06:54 PM
autotr8er autotr8er is offline
I'm experiencing a shudder at 65-70 mph under acceleration or going uphill. What was the fix?
Old 07-05-2008, 07:14 PM
kab716 kab716 is offline
Hey guys - Feeling your pain. I went to tire store to get balance rotate and align. But can not be balanced because the wheels are out of round. I have Steel stock wheels on a 2003 F250 and after I thought about it, I have never been able to get the tires fully balanced. I thought it was due to crappy discount tires, but now I know. The Damn wheels were screwed from the start. I know that they got worse over time. Guy at tire store asked if I hit anything, like curb or speed bumb too fast, but not while I was driving. I am the only owner. I watched the rotating of the wheel on the balancing machine and can see the egg shape. The kid worked hard on balance and felt like he got it good, but could not garantee. It was great for the first 1000 yards and then it went to crap.
The vibration is not at all speeds, it only happens when the harmonics are perfect and then the whole damn truck rocks up and down. The only thing to do is replace. SOOOO I bought a set of aluminun rims from a guy and will have them mounted soon.
My truck uses a 235 width on the steel wheels. The "new" rims use a 265 width tire. Any issues with this? Responses appreciated before I invest another $600+.
Thanks
Old 07-21-2008, 04:01 AM
BUKWAKR BUKWAKR is offline
i've had to have the driveshafts changed on my 05 and 07 i think that they are not completely balanced where they should be,after they were replaced no more vibrations. I have found if you put a leveling kit on a 250 you may need to shim the carrier bearing down anywhere from 1/16 to 3/16 of a inch.
Darrell
Old 08-01-2008, 08:14 AM
island8 island8 is offline
Jesse @ High Angle Driveline will solve all your problems!
Old 11-07-2008, 12:33 PM
ctanguma ctanguma is offline
Thanks, Larry
I FEEL YOUR PAIN, MY TRUCK IS DOING THE SAME AND THE DEALERSHIP SAID IT WAS THE TIRES. MY TIRES WERE A WEEK OLD, THEN THEY SAID IT WAS THE BALANCING OF THE TIRES THAT WAS OFF. IT IS STILL MESSED UP.
