Go Back   Ford Powerstroke Diesel Forum > Ford 08 and newer 6.4L Powerstroke Forums > 6.4L Problems Forum > 6.4 Drivetrain Problems
Old 11-21-2007, 06:14 PM
ex dodge guy ex dodge guy is offline
Tire presure sensor
I have a 2008 F250 diesel , I just had a leveling kit installed along with new rims and 35" tires, I now get a message about tire presure monitor failure.
The tire store does not have any any idea how to fix this. Has anyone had this problem?
Thanks, Ex Dodge Guy
Old 11-21-2007, 06:17 PM
Jon
Tournaments Won: 1
Posts: n/a
Hey
What are the tires set at psi wise? If they are not load range e and are set lower then the truck wants to see it will set the light. Also if it was damaged in the process.
Old 11-21-2007, 06:22 PM
slammedSI slammedSI is offline
The only thing that the tpms does is read pressure differances. Only way to reset the light is to have it reset with the tpms tool. not many shops have them my store does tho. and i believe al NTB's do.
Old 11-21-2007, 06:27 PM
mschn99 mschn99 is offline
ACTUALLY....the dont read differences in pressure...they read differences in tire revolutions per mile by using the ABS sensors in conjuction with the TPMS sensors
for the origional thread starter...ur gonna need to find out if the sensor was damaged or if its just wanting to be recalibrated now that the tires are a different size....
Old 11-21-2007, 06:40 PM
CAT797 CAT797 is offline
Sparkplugs Not Required
Don't you have a reset button that allows the system to recalibrate itself after it identifies a low tire and you check the air pressure? I'm just guessing here. My Buick regal has a reset button on the inside fuse panel........
Old 11-21-2007, 06:47 PM
benderado benderado is online now
Like everyone else has said, the tpms could have been damaged in the mounting process. However, look in your owner's manual under tpms or tire pressures, it should tell you in there if you can reset the sensor yourself. Other wise Discount tire should have the nessecary equipment to reset the senors for you (at least mine does anyway).
BTW: the only real way to find out if the tpms was damaged in the mounting process is to have the tire dismounted, by someone who knows what they are doing of course, and visually inspected. If it turns out it was damaged, have the store you bought the tires and had them mounted at buy you a new one (they are pricy!! about $250).
Old 11-21-2007, 07:20 PM
Thats not what i was told in my 6 day factory training class. I typed that exactly from my training book. But if you say so.
Old 11-21-2007, 07:23 PM
factory huh?? Ford doesnt offer a TPMS specific class..... so it wasnt factory....it may have been a generic TPMS class..but trust me...stuff varies so much between manufacturers that they can never touch on enough...
Old 11-21-2007, 07:26 PM
Maybe in cali. but there was a tech from ford and chevy at this class.
Old 11-21-2007, 07:29 PM
lol...point proven...if it was factory training...there would have been only one person from one company. Just the ford TPMS could be about a four day class....
its an intigral system with the ABS....trust me...there are two different TPMS systems just in ford vehicles...not to mention what chevy...im assuming dodge...and the imports have...
