Brake fluid in driver side floor 08 f350 - Ford Powerstroke Diesel Forum
post #1 of 3 Old 01-09-2013, 10:37 AM Thread Starter
05f250harley's Avatar
The company that i work for has an 08 f350 and the brake fluid keep leaking into the drivers side floor. I looked to see were its coming from and don't see it. Do you guys know what could be causing this and what to do to fix it?
Sent from my DROID RAZR using AutoGuide.Com Free App
05 Harley Davison Edition Arp head studs, SCT livewire TS, 03 turbo, PMM egr delete, PMM coolant filter, afe cai, blue spring, 6.4 banjo bolts, updated stc, standpipes and dummy plugs, 4" exhaust with no cat and no muffler
03 RCSB 205/100 warren injectors, BW s366, Lots of supporting mods to come
05f250harley is offline
post #2 of 3 Old 01-14-2013, 07:52 PM
Powerstroke Techie
Really the only way is through the back of the master but it would have to leak through the hydro boost too.
Either that it it is wicking down a wiring harness into the cab.
Are you having to add brake fluid to the master?
Is it a manual trans truck by chance?
Ford Senior Diesel Technician
2008 F-350 4x4 Off Road 6.4 Powerstroke Diesel
There are strange things done 'neath the midnight sun by the men who moil for gold.
The arctic trails have their secret tales that would make your blood run cold.
Big Angry Hillbilly is offline
post #3 of 3 Old 01-23-2013, 04:54 PM
K1LLsW1TchEd's Avatar
yikes, i had a small leak on one of the fittings on the master cylinder and the leak traveled down harnesses to the the firewall and wheel well. There are two fittings with " I believe15mm" nuts on them on front of the master cylinder. One had a slight leak. I just tightened those two fittings and problem was solved.
upper right corner of pic shows the 2 lines with fittings. if you stand in front of the truck they are to the right of the fluid reservoirhttp://www.dieselpowermag.com/featur.../photo_10.html
2@@8 F250 FX4 Supercab
SCT Livewire w/IDP's Tunes
S&B Cold Air Intake
Rudy's EGR Delete w/FloTech Elbow
33" Nitto Terra Grapplers
MBRP 4"Exhaust/5" Tip and Hollowed DPF
Bilstein Shocks
Kicker Hide-Away Sub
Drilled and Slotted Rotors
Rides:
2008 F250 FX4
2005 Mazda 6
2004 F150 STX
2007 Nissan Maxima SE
Coming soon: VW GTI
K1LLsW1TchEd is offline
