anyone else have squeaky brakes? - Ford Powerstroke Diesel Forum
Old 11-06-2012, 06:53 AM
GRI GRI is offline
I thought my front brakes were bad, so I pulled the wheels. all brand new brakes and rotors. I checked to see if the slide pins were stuck. they were not.
is this a normal issue with these trucks?
Old 11-06-2012, 09:19 AM
Not that I'm aware off. My truck has 29xxx miles with original break pads and still working fine.
Old 11-06-2012, 09:23 AM
No... :( I am that NEWB..
Send a message via AIM to GatorBaitR6 Send a message via Skype™ to GatorBaitR6
Mine has squealed from day 1 with new pads and rotors... It also depends on the type of pads u buy... As far as compound like really metallic and what not...
Sent from my iPhone using Autoguide.com App
Old 11-06-2012, 09:25 AM
Mine have squeaked since I replaced them. I've serviced them 3 times and they still squeal. Where did you get you pads?
Old 11-11-2012, 07:29 AM
Autozone I can't remember but I'm sure I got the nicer supposed to be quieter ceramic ones but it sounds like they are nothing but metallic lol
Old 11-12-2012, 01:41 PM
Feedback Score: 8 reviews
our brand new f450 has squeaked since the day we picked it up. took it to ford and said everything looked fine. I put brakes on my sisters explorer that were squeaking but pads and rotors looked fine. she had me replace them anyway because of the noise and still didnt fix it. i hate brakes
Old 11-12-2012, 04:47 PM
What he said... I'm contemplating changing the pads but I don't want to... The rotors are brand new so yea...
Old 11-12-2012, 06:54 PM
Seems like on our trucks when people don't use oem pads or rotors there is always some sort of problem. I still have original brakes 110k miles
Old 01-01-2013, 11:50 AM
Check for moisture. If your pads aren't worn, this is probably the culprit.
Old 01-01-2013, 01:47 PM
I was told once that squeaks are caused by dirty pads or rotors. I find that a good slam on the brakes from 40 or 50 mph to a dead stop will burn out and clean off any grime. You might try this a couple times, works for me.
