Go Back   Ford Powerstroke Diesel Forum > Ford 08 and newer 6.4L Powerstroke Forums > 6.4L Problems Forum > 6.4 Drivetrain Problems
  #11 (permalink)
Old 12-05-2007, 10:14 AM
willholl79 willholl79 is offline
my 01 6spd does the same thing.
  #12 (permalink)
Old 12-14-2007, 01:06 PM
aRibelin aRibelin is offline
Mine does it too; 325's. My 2000 did it too until I had the pump and gear overhauled to put out higher pressure. Limitations of the hydro-boost system. Drove my friends Toyota Tacoma the other day with the same tires as mine, it was like driving a car-you could literally steer it with one finger.
  #13 (permalink)
Old 12-14-2007, 01:19 PM
tysonmathews tysonmathews is offline
Send a message via MSN to tysonmathews
Smile
I just picked my '04 F350 up from Bowen Scarff in Kent, WA. It ended up being the stearing gearbox. It had a very very slight leak but caused me to be unable to turn the wheel, atleast with out worring about breaking something. Cost me $760 after tax for that portion of my repair.
My breaks were slightly spongly too as it is all interconnected.
  #14 (permalink)
Old 02-07-2008, 08:42 AM
johnbraddy johnbraddy is offline
my 08 f-250 has done the same thing a few times. but i have owned several fords and so have some of my family members. i personally just think it is a ford thing
  #15 (permalink)
Old 05-14-2008, 07:17 PM
champ198 champ198 is offline
me too. .
I've noticed that lately, when I start the truck and go to turn the wheel, it is like there is no power steering. But, it then seems to be ok once I start moving. Seems to only happen when starting the vehicle.
  #16 (permalink)
Old 05-14-2008, 08:02 PM
utah300rum utah300rum is offline
I just ordered a "AGR Super Pump" pt#877257 from Summit Racing. I wanted to get the rock ram kit that adds a hydraulic ram but it was out of my budget. I talked to 3 different people that have just replaced the stock pump with one of these. They all had very noticeable increase in powersteering and good reviews. The pump is not much to look at, so I hope it works better than it looks.
I talked with AGR before I got the pump, they really recommended the "Rock Ram" kit which comes with an upgraded pump, upgraded power steering box and adds a hudraulic ram. But you also have to change your pitman arm as well. They said its not a bad idea to replace the hydroboost to a specially ported unit as well, but they said that was not required. If money wasn't an option the Rock Ram kit is the way to go. I talked to several guys from Moab who build rockcrawlers and they say you can one finger turn aired down 44's with the diff. locked, no problem.
I will try to post my results after I get my pump installed, hopefully this Sunday.
  #17 (permalink)
Old 05-15-2008, 04:46 PM
Dusten Dusten is offline
Send a message via MSN to Dusten
my pump was leaking and having that problem
  #18 (permalink)
Old 06-21-2008, 06:11 PM
wirenuts wirenuts is offline
Send a message via Yahoo to wirenuts
what did he tell you to do i was doing a dounut in a parking lot and when i got out of it it was like i had no stearing i could not move it i poped the hood checked fluid and it was ok looked for leaks and i remembered i just unlocked my hubs "i hate that" and i drove in reverse and it got better untill i slowed down and when i say it got hard it was like it did not wanna move i had to use two hands to move it a little and its not like the norm stiff when parking it was hella tight now its fine when driving str8 and turns i have to be on the gas its a problem and can be fixed just have to find right person to know what how it happened
  #19 (permalink)
Old 06-21-2008, 06:25 PM
Punky Punky is offline
Hard Steering
I have a 06 F350 4x4 and turns fine at idle..but going down the road it's hard to keep straight. And if I turn a little to change lanes the steering wheel does not return. Took it to my loacal dealer and they told me that my steering box was binding and needed to replace for almost $1200.00. Has anyone elese had this problem or heard of somthing like this? Dont want to go and replace the box and still have the same problem!!
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
